Question about Casio SPF70T-7V Wrist Watch
Replace battery on Casio SPF-70T Wrist Watch - Casio SPF70T-7V Wrist Watch
SOURCE: Casio spf 40 Module 2273
Your Watch is in Auto or demo mode. Hold down the "Mode" button for 3 - 5 seconds and it will return to time keeping mode.
Cheers,
Murray
Posted on Dec 29, 2007
  • 4 Answers
SOURCE: how to adjust metal wrist band on casio watch?
  1. Pop out one spring pin to disconnect the band from the watch or from itself at the clasp. If you don't have a special tool for this, a needle or a pin will probably work. A straightened paper clip may be too thick, but they are cheap so you could try it. Now the watch and band can sit flat on the work table.
  2. Examine the links. If some of them have little arrows on them (usually the ones closest to both sides of the clasp), they are removable.
  3. These removable links are held together by a "U" shaped (actually a squared off "U" - sort of like this |_| ) pin that is inserted into the link. There may should be some kind of window-like opening in the link into which you can insert a narrow screwdriver or similar tool or even a small nail (around 6-penny size) and push out the |_| shaped pin. A straightened paper clip is probably not sturdy enough, but you could try it. Push in the direction of the arrow (from tail to point). The links that were joined by the |_| pin can now be separated.
  4. Remove a second such pin from another adjacent link. Now a single link is free and can be discarded (or kept). Reconnect the remaining adjustable links with one of the |_| pins and re-attach the spring pin from step 1 so the band is reunited with itself or with the watch.
  5. Try it on. If it is still too long, repeat the process. Good luck.
Posted on Mar 24, 2009
escapement
  • 2334 Answers
SOURCE: i cant set analogue time on casio hd wrist
Follow this link:
http://world.casio.com/wat/download/en/manual/
Rate, please.
Posted on Mar 31, 2009
SOURCE: can't set the time on my casio wrist watch
Press button A (top left) and hold for two seconds. The watch should then receive a time signal - you shouldn't have to set the time on it at all.
Posted on May 07, 2009
SOURCE: casio pathfinder SPF 70-s titanium band adjustment
I purchased a Casio Pathfinder solar/atomic watch, with compass, altimeter, barometer, thermometer, model 1200T-7WC (titanium).
Has the titanium band - on this particular band each link is somewhat waveshaped {i.e., there are 2 "arms" from the link making contact with the middle part of the link above (above meaning towards the watch body), and 1 arm fitting between the 2 arms of the next link down). Unlike described in the first solution, the pin is not split, but solid (doesn't look like a slotted screw on 1 end, so the solution at http://www.wikihow.com/Adjust-a-Casio-S-935L-Watch-Band is no help). Here's what to do if you have this band:
1. Note: before you start, be advised there is a tiny loose 1/8" part (sleeve) that will fall out as you pull the links apart, so work over an appropriate surface to "catch" it. Push pin (from the upper "arrow end) of one of the removeable links (those with the arrows on the backside) out of its hole with a fine poker (I used a 1/32" jeweler's screwdriver, an unbent paperclip would also work, just more likely to bend as you push pin out). This takes some force to do - in my case, after pushing, the pin projected out about 1/2 of it's length, I used needle-nosed pliers to gently pull it out the rest of the way). CAREFUL - once pin is removed and you pull the link away from the one above, a small (1/8") constriction sleeve should fall out of the center arm of the link above. SAVE THIS SLEEVE!
2. Using the same procedure, remove the pin from the bottom end of the link you're removing. again, SAVE THE SLEEVE.
3. to rejoin the band once the link is removed, look at the single/middle "arm" of the upper link, looking for the hole where the pin goes through. One side of the hole should be noticeably larger/wider than the other side - this is where you will place the SLEEVE - I used tweezers, or needle-nosed pliers will work - it will drop into hole. Keep this upright so that sleeve doesn't fall out, and slide the 2 arms of the lower link in place around the center arm.
4. Slide the pin you removed into one of the outer link arm holes - I found it easier if I started from below, pushing it into the center arm - it will stop when it reaches that 1/8" constriction sleeve. I set the extruded end on the pin on a magazine (i.e., slightly padded surface) and then pushed the top side of the band down, forcing the pin through the constriction sleeve and up into the upper arm hole, and Voila, your band is reconnected. The sleeve is important (without the sleeve in place, the pin will simply fall back out).
Posted on Mar 07, 2010
Where can I get a replacement band?
Ebay is a great place for special watch bands. this one is $30:
http://www.ebay.com/itm/CASIO-SEA-PATHFINDER-WATCH-BAND-BLACK-SPF-40-/330812864375?pt=LH_DefaultDomain_0&hash=item4d05fbb777
You can also go to the source, Casio, and purchase a new band:
http://www.casio.com/support/buyparts/
Oct 18, 2012 | Casio Sea Pathfinder SPF70-2V Wrist Watch
How to adjust/identify the correct tide on my sea pathfinder spf-40
Hi,you need to look at the user manual..
just in case ,if you need soft version of the user manual pls visit the URL below..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
Jun 21, 2011 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
I have a casio sea pathfinder spf-51 and i opened the case to see if i could change the battery myself.Unfortunately one of the 3 springs fell out and i cant see where it should go.Can anyone help me with...
mcdevito75 here, My best advise is to see how the other 2 springs are situated in the watch, then simply follow suite with the 3rd spring. BE VERY CAREFULL THOUGH AS< ANY OR TOO MUCH RESURE ON THE CASIO DISPLAY WILL RUIN IT. If you can"t find the spot for this spring, look for a small watch repair shop in your area for help, it"s better than ruinning your watch.
Jul 17, 2010 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
Body of SPF-40-1v
i have a spf40 casio, all is ok but interior display damaged viciorici@gmail.com
Aug 11, 2008 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
Cheers,
Murray
Nov 19, 2007 | Casio PRG-40T-7 Pathfinder
Casio SPF70T-7V Wrist Watch Logo
248 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
