Question about Samsung CLP-500 Laser Printer
Paper jams from top and side feed on clp 500. Any solution suggestions?
    Master:
  • 552 Answers
Dirty/jammed rollers - paper obstruction - loose parts - improperly inserted cartridges
Posted on Oct 20, 2013
leroyal
  • 2120 Answers
SOURCE: CLP-500N Paper Tray error
It wants you to put paper in the multi-purpose or pull down tray 1 assembly.
Posted on Jan 05, 2009
CompuFirm
  • 89 Answers
SOURCE: Samsung CLP-315 prints half a page and then stops
It sounds like your fuser is causing the jame,.
when you remove the paper can you wipe the toner off the page or does it adhear to the paper ?
If it does not the fuser is causing the jam, if the toner does not wipe off the paper then the feed tires would be the cause of your jam
The fuser is at the back of the printer and will be very hot, so be careful.
Posted on May 26, 2009
  • 3 Answers
SOURCE: Papr Jam, Samsung CLP310 - paper jams half way through the job
If it jams every page, it is the infamous Samsung design flaw. There are dozens of reports of this problem all over the internet. The best solution: sell it or otherwise get rid of it ASAP and buy another type or model of printer. The 2nd best solution: call trained technician and ask to replace the broken part. It could be thermistor near fuser, some people say it is a photo-interrupter.
Posted on May 05, 2010
Testimonial: "Thankyou"
  • 360 Answers
SOURCE: Samsung scx-4521F giving me document jam error
hello please check it properly.some time their have a small piece of paper.
or clean adf unit & service.
Posted on Sep 09, 2010
Doc Rings
  • 9 Answers
SOURCE: SAMSUNG CLP 315 paper jam
Where are the "sensors" located...?
Posted on Apr 05, 2013
Refusing to take paper
Someone suggested to empty the gray toner waste container located on the left side of the printer next to the cartridges. Be careful when emptying this as toner can make a real mess. Clean up with toilet paper or paper towel - not water!
Easy fix and this fixed mine like a charm. No need to send the unit in!
Feb 17, 2009 | Samsung CLP 300 Laser Printer
Error Jam0 in tray1
GO ON LINE TYPE IN MANUFACTURE NAME,MODEL#, ERROR MESSAGE AND ENTER KEY LIKE THIS:
CAMSUNG CLP-500 LAZER PRINTER ERROR MESSAGE JAM0
ENTER
ROD
Feb 09, 2009 | Samsung CLP-500 Laser Printer
Paper Tray Error CLP-500N
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 05, 2009 | Samsung CLP-500N Laser Printer
Paper Jam in CLP-550
Jan 02, 2009 | Samsung CLP-550 Laser Printer
Paper jam top o printer
disassemble printer and clean rollers with a rubber rejuvinator solution
Nov 21, 2008 | Samsung CLP-510 Laser Printer
Paper feed problem
Try changing the bottom margin in your print software.
Oct 25, 2008 | Samsung CLP-500N Laser Printer
Samsung clp 500
i cant answer but have same problem this printer was around $500.00 & is ****!
Jun 19, 2008 | Samsung CLP-500 Laser Printer
Paper jam
I too have this infuriating problem and the reason has already been pinpointed very well it is indeed the front rubber pinch cam not grabbing the paper well. I have approached this problem from another angle... under the front sprung loaded flap on the paper tray
there are two compression springsapprx 1/2" in dia. Gently prise apart the 2 flap pivot (on the extended arms) to gain access to the springs ,pull out the springs and either replace them with slightly stronger ones or pull the existing springs apart to retension them and pop them back (long-nosed pliers or tweezers) this will restore the spring tension lost during use with the rubber pinch cam.
Jabba0737
Mar 10, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP-500 Laser Printer Logo
29 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
