Question about Zenith XBV342 DVD Player/VCR
DVD/CD will not load and ejects
When I place a dvd or cd in the player, all it does is display 'load' then the counter on the player reads 000000, the it ejects the disk.
SOURCE: XBV442 DVD door won't open
I have opened many a player and given the tray a slight assist. Voila it unsticks
Posted on Mar 25, 2008
  • 99 Answers
SOURCE: DVD/CD will not load and ejects
junk it and buy a better dvd players fail quickly..
Posted on Mar 31, 2008
SOURCE: DVD will no eject
This is not helpful. The power is on and display is on, but no response.
Posted on Sep 08, 2008
  • 303 Answers
SOURCE: Need a new ac adapter for a DVP615 portable dvd/cd player (Zenith
You can buy a new one by clicking on the hyperlink:
buy replacement ac power adapter charger cord ZENITH DVP615
Posted on Mar 29, 2009
  • 95 Answers
SOURCE: My dvd player dvp615 doesn´t play dvd discs. only music cd´s
The unit has two lasers one for the cd and one for the dvd, the one for the dvd is bad and the whole laser assembly needs replaced. Cheaper to buy a new player.... sorry
Posted on Jun 12, 2009
  • 1175 Answers
SOURCE: Wont read disks
Wet a cotton swab with eyeglass cleaner and GENTLY buff the laser lens
( The little clear unit on the laser pickup/reader. Then dry off with another swab. If you can get a can of "Dust-off" compressed CO2, try a couple sprays of that towards the Disc reader.
If this helps, rate my help please.
Posted on Sep 30, 2009
0 characters
1 Points
Player won't load a blank DVD-RW disc
because there is nothing to read in blank cd rw , because dvd operating system is not meant to write cd ,but only to read the disk
Jan 31, 2013 | Samsung DVDR120 DVD Recorder
Jvc dr-mv100 won't eject dvd and doesn't sound like it's trying
Check and replace the CD loader mechanism. It is faulty. Do not loads CD onto reading deck properly.
Jun 06, 2012 | JVC DR-MV100B DVD Recorder/VCR
My dvd player ejects the cd when i load it
Either the reading head on the laser is dirty or bad and it is not recognizing the CD. If it is a homemade CD there might be a formatting problem that is not compatible with your player
Apr 17, 2011 | DVD & Blu-Ray Players
Won't read Dvd/Cd as loaded
It is a problem of the optical head being covered up by foreign particles obscuring the optical lens. Try using a CD/DVD cleaner disc which has double brushes and one add some solvent which comes along with the pack.Simply play it & keep ejecting and inserting the disc makes the disc to spin, till your player starts reading it..............................sodeep
Oct 06, 2009 | Coby DVD-224 Player
Loads dvd tries reading ejects dvd
Run DVD/CD cleaner CD using 2 drops of solvent on the brushes and run the cleaner CD twice, the last one being a dry one. If the DVD's are not scratched they will definitely play....sodeep
Jun 15, 2009 | RCA DRS720N DVD Player
Jvc dvd XV-N322S REGION CODE-2 is showing 'NO FILE'
It's a software problem pls upgrade ur dvd player.ur problem will be solved
May 11, 2009 | JVC XV-N322 DVD Player
Player won't read a DVD
Some DVD players requires installation of software to load some DVD's. Ask your dealer to provide you with a Software CD. Just insert this software CD and then try to run DVD it will work...
Oct 04, 2008 | Samsung DVD-R155
Feb 25, 2008 | Durabrand DVD-1002 DVD Player
Zenith XBV342 DVD Player/VCR Logo
286 people viewed this question
Top Zenith DVD & Blu-Ray Players Experts
Jonathon summesfield
Are you a Zenith DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
