Question about Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
Change the motor filter - Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
    Sergeant:
    Champion:
  • Electrolux Expert
  • 357 Answers
Change the motor filter :D
Posted on Oct 21, 2013
My canister motor shuts off after a few minutes and a red light comes on
hat's the thermal cut off circuit. If the motor gets to hot it trips and shuts it off. When it cools down it will turn on again but it is generally an indicator of one of the following; the cone filter needs changed or the inner filter ring that sits above the motor inside the unit is shot. One is an easy change the other requires dis-assembly, better carried out by a vac tech if you aren't comfortable taking it apart. In the meantime remove the cap out of the top of the vacuum, that will let it exhaust heat better but I strongly recommend getting that filter ring changed.
Nov 27, 2015 | Filter Queen Majestic Canister Vacuum
Eureka Rally 2 had great suction the first two times I used it and now faint. No blockage and new bag and clean filter. What coud it be?
The dust bag holder is an important part of this vacuum. Make sure the bag is installed into the holder sliding bag collar into slots to secure.
Make sure the bag is tucked into cleaner. or the bag cover will not latch securely.
Also, the motor and exhaust filters should be cleaned at each bag replacement.
REPLACING THE FILTERS
Filters should be cleaned or replaced when they become visibly soiled or suction power is reduced. Always operate the cleaner with the filters installed to avoid motor damage. The dust bag must be changed and the filters cleaned or replaced if the window of the Clean Filter Indicator changes into red when the cleaner is operating at maximum power and the nozzle is raised from the floor.
Dec 25, 2010 | Eureka Vacuums
If you dopn't change the hepa filter will motor burn up or explode
No. The HEPA filter is simply to collect fine dust and allergens that make it past the water. Hmm. If it gets full/clogged and isn't changed, then the motor is more likely to burn up from overheating. It's more likely it will shut off if the filter gets full. It will not explode.
Dec 17, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Dyson DC07 Vacume cleaner trips on thermal after 10 min motor not excesive hot resets after 15 min has been doing this for the last 3 mths. Could it be faulty thermal or motor overheat how can I check...
first, check both filters on that unit. the premotor filter on the side, and the hepa filter underneath the canister. if those filters are clean move through the suction channel and look for a clog or obstruction. also make sure the canister is clean. I have never seen the thermal go bad on those machines (not saying it cant happen though). it sounds like the filters are dirty or you have a clog. its also a good idea to change the pre motor filter if its older than a yr. the foam is fine but the white material behind the foam gets clogged frequently. let me know if you have any other questions and if this doesnt fix the problem.
Jan 06, 2010 | Dyson DC07 All Floors Bagless Upright...
How to change upper filters?
Open the vac as though to change the cone and remove the plastic inner cone with the slotted screw at the bottom.. Underneath you will find a 5" disk , likely coated with fine dust.
That is the one which needs to be changed. Around that disc will be three more screws holding the upper housing onto the vac. These ones are accessible from inside, if changing the motor.
Below the handle of the vac there is a serial number ring and three screws in an offset triangle. If you remove these and the rubber cover for the toe switch, the vac housing will come off. This will reveal the `foam or cotton ``muffler``. You can replace it or wash and dry it if foam. It acts as a muffler more than a a filter....
Oct 17, 2009 | Filter Queen Majestic Canister Vacuum
How do I install new filters on a Miele Blue Moon?
There are two filters on the blue moon. The hepa filter and the motor filter. You get to both filters the same way. You open the lid, like you do when you change a bag. The motor filter is right behind the bag inside a plastic cover. There should be two tabs you can pull down to open and access the filter. The hepa filter is located toward the back of the bag chamber but on top. There is one tab in the middle that lift up on.
Sep 23, 2009 | Miele Blue Moon Bagged Canister Vacuum
I need a wiring diagram & detailed specifications for my Filter Queen Majestic limited edition.
Open the vac by removing 3 screws below the handle area and the long screw at the bottom of the cone. If the motor has been removed, you will have 2 motor leads , 2 power head socket leads, and 2 switch leads as well as the cord. Do not twist your wires first when pairing, twist with the wire nut ony and tape afterword as there is metal nearby in the housing area
1 side of the cord goes to the switch only. The opposite side of the switch will go to 1 of each of the motor and Socket. The remaining motor and socket leads pair with the remaining cord lead.
While you are in there change the round filter dic covering the front of the motor and you could change the foam/ felt wrap around the inside of the housing.
There is a insulating disc at the top of the motor to prevent shock between motor and screen. Do not remove it.
Sep 07, 2009 | Filter Queen Majestic Canister Vacuum
Vacuum gets hot loses suction and turns off
you have replaced all three filters?
if its turning and sucking with all new filters you have a glog somewhere
Apr 23, 2009 | Filter Queen Majestic Canister Vacuum
Changing the HEPA filter on a DC17 Animal
Just took my Dyson in and yes my HEPA needed changing. It's under the right wheel (as you're looking at the machine); you can see it through the "vents" above the wheel. The screw is on the bottom of machine.
You will probably need a Torx (star) 15 screwdriver -- that's what Dyson seems to use everywhere.
Feb 18, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum Logo
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
