Black lines on each side no controls - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 75,471 Answers
What is the brand name to your TV? If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Posted on Oct 20, 2013
How to remove hoses on water filter housing
this is hard to explain but here goes..... push the water line in and at the same time push the flange in as well... this will realese the water line, holding inwards pressure on the flange pull the water line out of filter housing... I know this sounds confusing, but when you look at housing it will make more cense.... hope this helps........ ken
Oct 09, 2014 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
Water leaking from water filter housing
if water is leaking from where water line is try cutting the very end off water line and reinstall water line... if it is leaking any where else replace housing
My 1997 ford ranger a/c dash vents won't blow
Vacuum supply starts on the drivers side of the engine. There is a vacuum line going into the brake vacuum assist from the manifold. branching off of that line is a double line that snakes under the intake manifold, behind the valve cover, along side the valve cover on the passenger side headed to the front of the engine. Then it curves to the right side of the engine. One set of hoses from this line goes to a valve control (red and green i think). The other line goes to the vacuum storage ball, it should be black. The vacuum circuit continues out of the ball in another black line that snakes into the firewall. It goes under the heater core black box and disappears under it. Now go into the passenger compartment and drop the glovebox. look to the back right you will see a black and a white vacuum line coming out of the firewall. The black line is your vacuum supply from the engine. It goes up to a little rubber manifold. disconnect the lines coming from the dash switch and check for vacuum on the manifold where the black line is going in. The white line controls the cabin air intake under the glovebox and the thermostat shutoff under the hood. It should only have vacuum when the switch is in a certian position, AC probly. The other three lines coming off the rubber manifold snake behind the dash vent door assemble and come out near the gas peddle. The red one controls the dash vent. apply vacuum to the red hose and see if the vents go to the center dash position/AC. The yellow and blue? ones control the floor vent control near the gas peddle. yellow gives you half floor and half defrost. blue gives you all floor. you can use a small vacuum line to connect the black vacuum supply to each individual line on the manifold and check the function of each vacuum control assembly individually. I hope this helps. On my truck each control unit works fine when i apply vacuum to them individually but when I hook the dash switch up to the rubber manifold it goes to defrost. I tried changing the dash switch and the lines running from the switch to the rubber manifold and the vacuum ball under the hood, nothing works. I suspect I may have leak i just haven't found yet. next step is to get a vacuum gage and start checking the amount of vacuum i am getting at each vacuum line. I'm sure it is supposed to be getting a specific amount of vacuum and will not work if the vacuum drops below a certian level due to a leak in a line somewhere? God bless.
May 28, 2012 | 1997 Ford Ranger SuperCab
Have a 2008 Ford E450 Class C M/H with a Triton V-10. Rats chewed up a vacume line. Facing the engine, left side of the intake manifold near throttle body is a connection with two RED plastic vacume...
Same chewed red vacuum A/C damper line passenger side. splices to black line above the AC coil box. Removed battery and holder. Loosened A/C dryer mounts from inner fender. Removed fan motor. Interior passenger side lower right corner of the air input damper is the entry port for the black vacuum line. Removed clear rubber entry port weather plug/seal. Pulled the damaged black line out of the weather plug/seal. Ran a wire fish line from interior to exterior below left corner of the fan motor. Taped new line to fish tape and pulled new line into the cab. Reinserted new line into weather seal and reinstalled in reverese.5272c02f-9f6f-488e-a428-1e30a8342318.jpg719d1a3c-a72e-4a51-8201-9073ae2d31f3.jpgdbe7d6e5-21ea-4dd1-a9ec-2431f56b292c.jpgbffdab4a-8c8a-4aaa-9d1d-b9bf8c0e8fb3.jpg
Aug 05, 2011 | Ford Econoline Cars & Trucks
How to wire a t30 1 phase 230 volt in control box, they used white black green, are the white and black both line voltage for 230 volts? its a model 2475
yes white and black are both line voltage in.each wire will have 110 to 120 volts. Attach one wire to top of starter contactor left side the other to top of starter contactor right side. Attach green wire to ground.
Jun 01, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
Solid 2 inch black line from top to bottom
Your tv has a vert. circuit that controls your pic from top to bottom.It also has a circuit that controls the pic from side to side.Your horiz.(side to side) has collapsed.
Sep 25, 2010 | Panasonic TH-50PX75U Plasma HDTV
1" black vertical line in center of screen. Sony Plasma.
NOT DEFECTIVE!!!
There are 4 or 5 ribbon cables on the bottom or on one side, they control part of the plasma screen. Check the ribbon cable2_bing.gifnear the black lines. Unplug the ribbon cable and look for black chipson the underside of it, I think they say 100 on them, you need toresolder both ends on each chip. Should fix the black line issue.
Aug 19, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
One big black verticle line 2 inches from left side...Help
Honestly you have a big problem because the driver IC & Tape Carrier Package inside controller board at vertical area are damage or itself defective could cause you have 2 inches line appear in your display. The best solutions for this replace lcd panel to fix vertical line.
Mar 28, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Thin black lines (mp 530)
Here's the link for how to clean the unit... I was going to post the instructions here, but there are pictures that might be helpful to you.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13371
Before doing anything more drastic, I would try this.. let us know how it turns out.. if it doesn't work, we'll go from there.
Maggie B
Feb 23, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
