Question about Refrigerators
Kitchen aid freezer gets ice . freezer on bottom
  • 31 Answers
Probably heating element in freezer is broken.
Remove power and defrost. Remove wall panels in back of freezer to Check heater element behind panels With ohm meter should read 20 ohms or less. You could remove it and bring it to a local repair shop and have them test it and if required order you a new one. If this does not work it may be the control board
drain below heater which should go into pan at bottom may be plugged.
Posted on Nov 07, 2013
peyton32034
  • 410 Answers
SOURCE: Bottom of Maytag Freezer Ices Up
You have a plugged defrost drain. easiest way to fix it is unload freezer compartment defrost all of the ice, then remove the 2 screws that hold the rear cover in place about half way down the back wall. once this is removed use hot water to flush out the aluminum evap pan at the bottom of the coil. once it is cleared i will usually pur a little bleach in to kill any algae build up.\
be sure to unplug the refrig and use caution not to cut your self on the evap coil as the fins are very sharp..
Posted on Dec 16, 2007
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Posted on Feb 18, 2008
  • 1314 Answers
SOURCE: Kitchen Aid Superba...freezer shuts off..
sounds like your defrost drain is frozen or blocked its in the freezer side under the back panel beneath the evaprator
Posted on Jun 03, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Ice build up on bottom of freezer. Water leaks out.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
Posted on May 21, 2009
SOURCE: Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Posted on Aug 30, 2009
Freezer not getting cold and dripping water
I own a similar Kitchen Aid fridge that had a defrost icing issue: Kitchen Aid KSRP25FNBL00
> Ice had plugged the drain hole at bottom of chill coil section inside the freezer compartment.
> I learned that the coil, circulation fan was not working, but condenser was working.
> I paid a tech to replace the circ fan, about $200, including a new swiss-made fan. He said it was unusual for these fans to fail, but not unheard of.
Expensive, but saved the purchase of a new fridge. Has worked great for 6 months since then.
HOpe that helps.
Al Zayha
Mar 09, 2014 | KitchenAid (KSRD22FKST) Side by Side...
How to defrost freezer in kitchen Aid bottom drawer freezer
My kitchen aid bottom drawer freezer kept melting and freezing to block the drain and then water would leak out all over the floor. I did the WHOLE fridge/freezer defrosting process once, when i really just needed to do the bottom.
I have had issues with other Kitchen Aid (NEW BTW) appliances so I've talked to many repair people. One guy who came out to fix something else, told me that the freezer is really a pain to get to close completely. SO, when you don't close it all the way (Extra push) it will melt and then re freeze when it is closed properly. He suggested I take everything out, leave it open and use a hair dryer on the ice until it melts. Then use a wire hanger to unplug the drain to make sure its draining properly.
It works! You really have to make sure the drawer is shut ALL the way. I have a 2 yr old who is constantly opening it up...this is my issue! The seal is not that great and you have to really push it closed to prevent the ice build up issue.
Hope that helps!
Sep 10, 2013 | KitchenAid Refrigerators
Kitchen Aid bottom freezer KBRS22KK is frosting up
Replace the "defrost thermostat" located on the coils in the freezer. Here is the part to order.
Dec 01, 2012 | KitchenAid KBRP20EMSS Bottom Freezer...
The ice cube tray won't fit can you or how do you adjust the cifiguration of the freezer comaprtment to allow it is a bottom kitchen aid freezer
This is a common problem,Throw the tray in the bin and buy ice cube bags from any supermarket. You will produce a lot more ice and bigger cubes.
Regards
Steve
Jul 22, 2010 | Refrigerators
Kitchen aid bottom freezer dripping sound
drain cloged behind freezer panel?
Aug 26, 2009 | Refrigerators
I have a kitchen aid refrigerator freezer. The
the supply line of the ice maker might be blocked please check it.
Aug 18, 2009 | Refrigerators
Ice maker makes too much ice
In my Kitchen Aid bottom freezer there is a metal arm(?) that I lift up to stop the ice maker from making ice. When I start running low on ice, I push the metal arm(?) back down for it to make ice again. Hope this is the solution for your Kitchen Aid too.
Jul 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
blinking
Del
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Jun 03, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
79 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
