Question about Elfa The Container Store Shelving
My 60cm gliding basket isn;t fitting under my 60cm shelves. What am I doing wrong?
Can i remove the shelves in frigadaire frezzer model frs6r4eq4
Good Afternoon Friend,
I understand you want to know if you can remove the freezer shelves in your Frigidaire refrigerator, model# FRS6R4EQ4. All the shelving in your freezer is fixed, however the bottom shelf, which is located on top of the freezer basket, should flip up to allow more room for tall items that you wish to store in the freezer basket. Hope this is helpful.
-Best Regards-
WP
Jun 14, 2014 | Frigidaire Refrigerators
60cm to feet
One foot is exactly 30.48cm, so 60cm is about 23.6 inches, just a bit under two feet.
Apr 14, 2014 | Office Equipment & Supplies
Fuel gauge stays pegged out what's wrong
Make sure the float isn't caught on the side of the tank. If it's not, chances are the gauge itself is bad. Also make sure the connection under the tank is good.
Sep 27, 2012 | 2001 Harley Davidson FLHT Electra Glide...
I need shelves for my little tikes country kitchen
Sure, they can be found on amazon, here: Amazon com little tikes shelves. Wish you best of luck. Cheers
Jun 27, 2012 | Little Tikes Toys
I need to know what kind of baskets that can be used on m91 wheel chairs. thank you .
Mid-wheel drive Power Chairs can only use baskets that attach to the rear of the seat. I know this isn't much help to the user in the seat to reach around to use and also leaves any items placed in the basket open game for someone walking by with sticky fingers. Other than a flat tray for the front, there isn't anything else available.
The best basket will have a square post attached at the bottom and it will slide into the matching receiver bracket located under the seat. If your chair does not have the receiver under the seat, then you will also have to purchase that add-on accessory as well as the basket. Look in the phone book in your town to see if there is a medical store that sells mobility accessories. You should be somewhere in the $70 to $80 range for the price.
I have worked on power mobility for 20 years and have often though about inventing a front basket for the Pronto and other mid-wheel drive chairs. The problem is with the expense of the red tape just to do patent searches and then there is libiality issues to deal with as well.
May 16, 2011 | Health & Beauty
I installed a black granite sink, but the BASKET STRAINER is leaking. Do I need to buy a specific Basket Strainer for the Granite sink and take model # of the sink.Or can i just buy any basket...
Hello.
You shouldn't need a special strainer.
Where the strainer meets the sink surface, ( the lip of the strainer ), should have plumber's putty.
Take a chunk of plumbers putty and roll it out like a snake and then stick it under the lip of the srainer all the way around. Set the strainer in the hole and then on the bottom side add the rubber seal, then the cardboard, or metal glide ring and then the nut.
As you tighten the nut it will squeeze out the excess putty and allow you to remove it.
1. Sometimes people try to use the rubber seal on the top side of the sink, but it goes on under the sink.
2. The cardboard/metal glide ring prevents the nut from tearing up the rubber seal so you can really tighten it.
I hope this helps you!
Thanks, Donnie
Mar 25, 2011 | Franke Kindred DP2233/90/1 Granite Double...
Our two lower slide-in baskets will not stay on track. Even when the load has been reduced, the baskets fall off the track. I have tried to bend the sides to better reach the track, but it doesn't work. ...
No, very rarely internal shelves can be moved between generations. Unfortunately all you can do is an improvisation to keep them in place: you need to make the channel walls higher by gluing some small pieces of thick plastic on them using a powerful adhesive - not superglue, something like Loctite Sumo Glue.
Sep 10, 2010 | Kenmore Freezers
The freezer drainage
you have a clogged defrost drain, remove the bottom basket, and freezer shelves to expose the screws for the back panel remove back panel,carefully chip away ice, and or use boiling water to melt the ice from the drain hose, check complete drainage by removing back panel behind frige at bottom and inspect that the water is draining completely into defrost pan. reoplace all parts.
Aug 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Elfa The Container Store Shelving Logo
74 people viewed this question
Top Elfa Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Elfa Furniture Expert? Answer questions, earn points and help others
