Question about Radio Communications
How do i programe motorola talkabout 2 way radio MR 350 frs/gmrs
Motorola two way radio MR350R FRS/GMRS
  • 6 Answers
Open the package and read the instructions.
Posted on Oct 21, 2013
  • Jeffrey Morris
    Jeffrey Morris Nov 04, 2013
    You need a programming licance from motorola Re: Jeff
2 Suggested Answers
eradiostore
  • 1654 Answers
SOURCE: can motorola talkabout T5720 FRS/GMRS talk with
Your GP338 would need to be reprogrammed to one or more of the frequencies available in the T5720. If you are using the interference code eliminator, it would also need to be programmed into the GP338. Take your GP338 to your local Motorola dealer for reprogramming.
Here is a link to the user guide for the T5720, where you will find a list of frequencies: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf See page 19.
Best regards.
Posted on Feb 23, 2011
Can two different style motorola 2 way radios be changed to same frequency
Hi Kate,
The short answer to your question is: no, or "not readily". Here's why:
The Motorola 4900 radio operates in the FRS (family radio service) and GMRS (general mobile radio service) in the UHF band. This radio will work with any other FRS / GMRS band radios (no reprogramming of transmit and or receive frequencies is possible for these radios). The trick is that the numbering of the channels may differ from brand to brand ie: Ch1 on your Motorola may not necessarily be Ch1 on a Midland radio or other brand. A complete list of the frequencies and channel assignments for FRS /GMRS can be found on Pg. 17 of the manual. It is important to note that without a valid GMRS license, you are prohibited from transmitting on the GMRS only channels (Ch 15 through Ch 22). The combination GMRS/FRS channels (Ch1 through Ch7) and the FRS only channels (Ch8 through Ch14) are for individuals and family members that do not have valid GMRS licenses. If this is you, you should limit your transmissions to Ch1 through Ch14 only, as FRS does not require a license in the US. Unlicensed use of GMRS only Ch15 through Ch22 can result in fines and imprisonment if caught by the FCC.
Further complicating the issue are the so called "privacy tones". This is simply a very low or "sub-audible" frequency that is sent whenever transmitting. Motorola calls these "Interference Eliminator Codes". When another radio receiver is set to listen for a particular privacy tone, it stays silent until a transmission with the exact same privacy tone is detected. Again, these tones are listed in no particular order, but are generally listed as 1, 2, 3, etc. or a, b, c, etc. instead of the actual frequency in hertz. You can selectively set your radio to transmit & receive one of the 38 codes or, set the code to "0" to communicate with radio that do not offer these privacy codes - or does not use the same frequencies for these codes. You can read more on Motorola's codes on Pg. 19 of the manual.
The Motorola CP200 radio on the other hand is a commercial radio, and requires computer programming with Motorola software. The CP200 is offered as both Low & High sub-banded VHF and Low, Mid & High sub-banded UHF radios. You would need to have a CP200 that is designed to accept the Mid UHF band (438Mhz - 470Mhz) frequencies in order to program the 462Mhz & 467Mhz FRS / GMRS frequencies into it. The final obstacle would be what is called "FCC Type Acceptance". The CP200 is probably NOT Type Accepted for transmitting FRS/GMRS frequencies, and as such the Motorola dealer doing the programing might balk at putting them in. You can read a spec sheet on the CP200 here.
I hope this helps & good luck!
Feb 29, 2012 | Motorola Radio Communications
What is the frequency band for sx700
The Motorola talkabout SX700 2-Way Radio is capable of operating on GMRS/FRS bands.
Here are the Family Radio Service and General Mobile Radio Service frequencies: http://en.wikipedia.org/wiki/General_Mobile_Radio_Service#Frequency_chart http://en.wikipedia.org/wiki/Family_Radio_Service#List_of_FRS_channels
Aug 26, 2011 | Motorola Talkabout SX700 2-Way Radio
Can you use 2 different talkabouts fr50 and t5420 with each other? I have just one of each unfortunately.
  • Yes they will both talk together on the same channels just fine. Most of the more recent Talk About Radios are FRS/GMRS with 22 channels. These radios are FRS only with out the GMRS. The FRS are the first 14 channels in most talk about's as are your radios.
Regards, Tony
May 01, 2011 | Motorola Talkabout FR50 (14 Channels)...
Will the motorola mr350r work with the motorola cs1110
  • The mr350 is a standard GMRS/FRS talk around radio and the cls1110 is a business band radio but bot operate in UHF. So if the cls1110 is programed to one of the frequencies I will list then the two will communicate. Otherwise they will not.
Here are the frequencies listed in order of channels on your radio. 1-22.
Apr 30, 2011 | Motorola MR350R Two Way Radio
I want to know in wich frecuency works this radio VHF or UHF
  • Ultra High Frequency (UHF)
  • This is a FRS/GMRS radio
  • FRS (Family Radio Service) Chanel's 1-14
  1. 462.5625
  2. 462.5875
  3. 462.6125
  4. 462.6375
  5. 462.6625
  6. 462.6875
  7. 462.7125
  8. 467.5625
  9. 467.5875
  10. 467.6125
  11. 467.6375
  12. 467.6625
  13. 467.6875
  14. 467.7125
GMRS (General Mobile Radio Service) Channels
  • 15. 462.550
  • 16. 462.575
  • 17. 462.600
  • 18. 462.625
  • 19. 462.650
  • 20. 462.675
  • 21. 462.700
  • 22. 462.725
Regards, Tony
Apr 28, 2011 | Motorola TalkAbout T5000 2-Way Radio
Frequency range
The T5720 has
- 7 GMRS/FRS 1 watt Channels
- 7 FRS 1/2 watt Channels
- 8 GMRS 1 watt Channels
All of these frequencies are between 462-467 MHz. There is a list of the specific frequencies assigned to each channel on page 19 of the user guide. Here is a link http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Best regards.
Jun 16, 2010 | Motorola Talkabout T5720 (7 Channels)...
Radios will not trasmit
The Motorola T-6510 uses FRS-GMRS frequencies the TK-3130 uses 2 UHF frequencies. Unless you had the radio custom programmed to match the GMRS frequencies it will not work.
May 04, 2009 | Motorola Talkabout T5100 (14 Channels)...
Same station same code only working one way motorola 250
If one set has FRS and GMRS channels and the other doesn't, the FRS channels may not match. Try using the lower channels or going up or down one channel.
Aug 14, 2008 | Motorola Talkabout FRS 250 (14 Channels)...
Communications
Yes, but depends on the configuration/setup and programming/frequency assignation of the MTS2000.
To my knowledge, the UHF version of the Motorola MTS2000 are designed to operate either in the 403~470Mhz or the 450~512 or 520MHz band.
On the other hand, Motorola TalkAbout Radio are design limited to operate in the FRS band which is 462.5625~462.7250MHZ and/or the GMRS band which is 462.550~467.725.
So technically, both the MTS2000 and the FRS/GMRS share some frequencies. What needs to be done is to re-program the frequency allocation of the MTS2000 into its channels to match the TalkAbouts frequencies. The other way around is not possible. TalkAbouts frequency assignments can not be reprogrammed/changed. Below are typical TalkAbout Channels/Frequencies.de11c4e.jpg
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 04, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Radio Communications Logo
97 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
