Question about Fisher Price My Little Snugabear Cradle n Swing
The power light is flashing and my swing does not work, what is the problem?
I Have a 125fes Swing F1 flashing 9 times and then stays on & flashes 9 times at low speed or when stopped
Hi, Anonymous your ECM has generated fault code #9 for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Honda Motorcycles Fault Codes motorcycle manuals PDF
http://www.partsfish.com/page/oem-parts-for-honda
Flashing F1 Light Servicing Technical Questions
http://www.honda-montesa.es/manuales/FES125_150_07.pdf
Honda Zoomer Service Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 29, 2016 | 2011 Honda SWing 125
Volkswagon polo doesnt start epc light on
Have the fault codes read and replace faulty sensors
Mar 24, 2013 | Volkswagen Polo Cars & Trucks
Natures purest swing won't swing
I have the same problem. Works fine then next time I go to use it it won't work.
Feb 21, 2013 | Summer Infant 66010 Nature s Purest...
The swing stopped playin all together
usally if its house power black is hot wire white is neutrel green is ground if its 12 volt powered black is ground and white is positve so the black wire has to be grounded for it to work.
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_8b3f0f0fc5f566a7
Aug 03, 2017 | Fisher Price My Little Lamb Cradle N Swing...
I ned a manual for the boppy rock in comfort travel swing. i am working off an apple computer and do not have a flash player
I cannot locate the manual on their website, links to it from elsewhere on the web show an error on their site. I recommending contacting the company:
Kids II, Inc. 555 North Point Center East Suite 600 Alpharetta, Georgia USA, 30022-8234 tel (770) 751-0442
Jul 24, 2011 | Kids II Boppy Rock In Comfort Travel Swing
The Bright stars swing is not working anymore. We put in 4 new D batteries but the swing does not have the same power? What can we do?
You'll probably need to replace the motor in the swing. Most of these types of swings work off a motor with a plastic gear attached, and the inside of the gear gets worn down over time. The motor still gets power and still turns the gear, but the gear doesn't have the grip that it used to so the swing doesn't move as much (especially with a baby in it).
Feb 04, 2011 | Kids II Bright Starts Travel Swing
Can't swing the bat with the controller
check if the lights on the pad are flashing you need to sync the pad
to do this you hold the red button inside the battery casing and the
red button inside the SD slot casing and wait till the light stop flashing
and go to the light corresponding to your controller
that is it it should work and be synced for every game
Jul 21, 2009 | Nintendo Mario Super Sluggers for Wii
Wii remote turns off
It sounds like you either have a low battery, or your motions may be dislodging the batteries on your controller. When the controller is off and you press a button, check to see how many of the four blue lights on the bottom of the controller are flashing. This tells you how much battery power you have: four lights is full, one light is low. If it's saying your battery is full, try taking the battery or batteries out and putting it back in. Good luck!
Jan 08, 2009 | Nintendo Wii Console
Fisher Price Nature's Touch Cradle Swing - Not Swinging
Parts for your model can be found on amazon, here:
Amazon com fisher price swing replacement parts. I hope this helped you. Best of luck
Oct 03, 2008 | Baby Gear
Fisher Price My Little Snugabear Cradle n Swing Logo
509 people viewed this question
Top Fisher Price Baby Gear Experts
Lyle Siemens
Lyle Siemens
Jennifer Rock
Jennifer Rock
Are you a Fisher Price Baby Gear Expert? Answer questions, earn points and help others
