Magic chef washer
Washer not getting hot
  • 156 Answers
The hot water supply line could be obstructed by a clogged filter screen. Turn off the water supply, disconnect the supply hose at the rear of the washer, and there should be a screen filter just inside the connector. Clean it with a stiff toothbrush.
Posted on Jun 23, 2014
3 Suggested Answers
richroth
  • 9472 Answers
SOURCE: I have a magic chef 20 lb capacity heavy duty
If your washer will wash (agitate) your clothes but does not spin well, you will need to replace the "thrust bearing" in the washer. The repair is simple and will only take you a short to do. Here is a link to the "thrust bearing kit" you will need.
Posted on Jan 07, 2011
I've had the spin problems with this nodel also. It would spin but not at high speeds leaving the clothes wet. Replacing the thrust washer kit still did ot fix the problem. After checking the high speed curcuit it was found that the contacts in the fimer were burnt and lacked follow. Adjusting the spring slightly and cleaning the contacts fixed the spinning problem but introduced minor timing issues. Finally, I replaced the timer and the washer was spining at hiper speed. Like New!
Posted on Oct 23, 2013
What is the error code E2 for Magic Chef 2.1 cu. ft. Top Load Portable Washer?
I put this answer in the comments but re-posting here because I didn't know what I was doing : )
The Magic Chef 2.1 cu ft Portable washer manual says that its a door malfunction and the solution is to open and close the door. That did not work for me so if you're having the same issue that I am it may be that your washer is not level. I had placed mine on top of a few folded throw rugs to stifle noise (I live in an apt, on the second floor) and the rugs were uneven. As soon as i adjusted them, the washer began to work again. I hope this helps.
May 26, 2014 | Magic Chef Washing Machines
Magic Chef CAV2005AWW Washer Drain hose is about a 6 inches to short to my sink..how do I replace that hose with a general longer one? I cannot seem to find extensions and the hose disappears into the back...
you should be able to purchass a connector, then if you can get an old pipe same diamiter join them. tip when you join them heat the pipe in hot water, and this will then push on fairly easy. Also if you use a little glue on the connector then this will dry and work as a seal.
Feb 18, 2010 | Magic Chef CAV2005A Top Load Washer
MAGIC CHEF WASHER WONT SPIN OUT
underneath the washer is a pully assembly kit . remove the belt ,the c clip and replace the pully kit about $ 20.00 cost for parts.
Feb 02, 2010 | Magic Chef CAV4000AWW Top Load Washer
Magic Chef 20lbs hd won't agitate
Try these
  1. Test the lid switch
  2. Inspect the motor coupler
  3. Inspect the drive belt (belt drive only)
  4. Inspect under the washer for soot (clutch)
  5. Test the motor
  6. Inspect the pulley
  7. Test the transmission
  8. Inspect the agitator
  9. Inspect the pump coupling
  10. Test the water level switch
pls rate my suggestion.......
Jul 23, 2009 | Magic Chef CAV2000 Top Load Washer
My washing machine is not working properly when moving the washing machine out of my apartment I noticed that one of the pulleys was ruined and the washing machine was smoking very badly it is the pulley...
Go to repairclinic.com or partselect.com to get the parts, you will need a model number.
Honestly I dont know if Magic Chef even builds washer anymore or has in the past several years. with that I would assume your warranty has expired. You will need copies of when you bought the washer and a copy of the warranty to full fill any warranty claims plus an authorized Magic Chef service agent will have to preform warranty work if it is still under warranty.
Jul 09, 2008 | Washing Machines
Magic Chef washer 15 years old, fills slow no hot water
Pull the hot /cold hoses off and clean out the 2 screens in the valve.Put the hoses back on and re try washer .Problem solved?If still no hot water ,replace your water valve. Please Rate This !!!!
Jun 19, 2008 | Magic Chef CAV2000AWW Top Load Washer
Washer wont spin
if the belt under the washer is intact then the transmission is bad. generally its time for a new washer unless its still under warranty
Nov 22, 2007 | Magic Chef CAV2000 Top Load Washer
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
