Question about Smeg A2.5 Dual Fuel (Electric and Gas) Kitchen Range
My smeg gas oven and grilled always go off when cooking
2 Suggested Answers
richardsimpl
  • 230 Answers
SOURCE: I have a smeg A42-5 oven and the digital clock as
Hi There
I have found this for to read and hope this will help you. Let me know how it goes.
The clock stopped The non-electronic clocks on electric range/ovens often don't last long. That's a problem, because the clock is essential to the self-cleaning and timed-bake features. Clocks are rarely repairable--you usually just have to replace them. Electronic clocks have been more reliable. But, they're often integrated with several other features of the range/oven. So when the clock develops a defect, it often renders the entire oven and broiler inoperative. The electronic clock is usually integrated with a circuit board, and the touchpad that holds the buttons you press is often a separate component. If your electronic clock is defective, you may need to replace the touchpad, circuit board, or both. Although these may be expensive, they aren't usually very complicated to replace.
Thank you for writing to fix ya.
Best Regards Richard
Posted on Jan 07, 2010
Testimonial: "Thankyou for your response I suspected that it will require a new clock which I have located online. many thanks"
Smeg oven stopped working
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jan 27, 2012 | Smeg Ovens
Hi, we have a se280x oven and its about 4-5 years old and inherited this when we moved in 2 years ago. But the oven seems to heat sometimes or not constantly and especially seems like e the upper and...
Apr 15, 2011 | Smeg SE280X Stainless Steel Electric...
Our smeg oven is not working. the clock is on but the oven and grill will not work? Help!
Check that the oven is on the 'manual cooking' setting rather than Automatic, if its on Auto it will not come on until the time set.
Dec 12, 2010 | Smeg Ovens
SMEG SA410X-S heat not coming on for fan forced cooking. The fan and light work, and the heat works fine for grilling.
The fan element (round) is more than likely blown. Open the oven door, take the rear cover off inside the oven (covers the element) and have a look at the element with a torch. If it is buckled, warped or has a blow hole in it, then it's faulty.
Mar 18, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Fan but no heat
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on Facebook please
Mar 14, 2009 | Smeg SE280X Stainless Steel Electric...
Manual for Smeg SE398X
SMEG have all their manuals online. The SE398X series is at http://www.smegtech.com/site/smeg/myapp/libretti/index.php?model=SC110&lang=EN
Nov 07, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
I need users guide
I need to replace oven light bulb for  Smeg gas oven range cook unable to take cover off to get at bulb any ideas how this is done?
Oct 28, 2007 | Smeg SUK61MFX Gas Kitchen Range
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Smeg A2.5 Dual Fuel (Electric and Gas) Kitchen Range Logo
46 people viewed this question
Top Smeg Kitchen Ranges Experts
ashburton
Joseph Mueller
Joseph Mueller
Your Consultant
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
