Jammed dvd logic L22fed12 tv can not eject dvd screen says disc not loaded and disc not ready .help appreciated
  • 163 Answers
SOURCE: Cannot play this disc
remove the cover and see if the dvd run, if not you got a motor problem or a motor drive one,if yes then try cleaning the reading eyes(pickup)by blowing dry air (get a can at radio shack)check for goods, if dosent work, take it to a shop for a repair thats all you can do, is a job for a tech....good luck
Posted on Aug 10, 2006
SOURCE: GPX d2816 problem
hey i know what it is ...i had the same problem and i took the top off and found the whole carriage for the disc inside has slotted holes and is adjustable.i simply moved it around until it worked then tightened it into place. hope that helps...... good luck badsdaddy
Posted on Aug 21, 2007
eswaran73
SOURCE: Loading DVD-RW discs
My recorder has stopped accepting NEW DVD-RW discs and ejects them.
There is no problem loading DVD-R (new or recorded)or loading previous recorded DVD-RW, initializing and re-recording
I have tried several different DVD-RW makes. Puzzling??
Posted on Nov 08, 2008
  • 98 Answers
SOURCE: player won't read a DVD
Sounds like a bad pick up assy (Laser)
Posted on Nov 25, 2008
  • 1810 Answers
SOURCE: when I insert disc screen comes up saying Disc Error, Eject disc
dirty dirty dirty
clean the dvd player
Posted on Jul 29, 2009
19 in. Coby TFT LCD TV with side-loading DVD player. How do I remove a stuck DVD?
Hi Joanne, The eject button ( micro switch ) on the TV is defective. Please get it changed and the stuck DVD will come out.
May 28, 2015 | Coby Televison & Video
Cd wont eject out of t_v
Disc loading mechanism fault. Contact any service technician. The mechanism should take out from the TV; either for repair, or replacement. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Sep 21, 2014 | Televison & Video
Upgrade software **** smith ge6826
Could someone please Help, I have a Dick Smith 21.5"(54.6CM) LCD TV with DVD Combo. I am having trouble with Loading DVD"s When I Load them it keeps coming up "NO DISC" and locks in the player, I have to turn TV off and turn back on holding the open/close button to eject the disc. I have tried 25 DVD'S and it has done it with all of them. I have reset The TV and reset the DVD Set-up options, still no Luck.
Your help would be appreciated.
Peter
Jun 22, 2014 | Televison & Video
22" Logic tv does not get a signal from arial
is it the is it the Logik L22FED12 22" LED TV with dvd Combo that is having the problem or the LG 32LD550 32 in. ??
Jun 01, 2014 | LG 32LD550 32 in. LCD HDTV
Dvd will not eject
Jammed.
Straighten one end of a Norwegian paper-clip.
Insert that end into the small hole in the face-plate.
Push until you feel resistance.
Firmly push another 5mm to "unlock" it.
Then, press OPEN.
Jan 01, 2014 | Sanyo DVW-6100 DVD Player/VCR
Dvd player immediately ejects all disks
the fault is with its disc loading mechanism. Replace the loading belt first. It it do not help you, replace the loading mechanism as a unit.
Jul 15, 2012 | Insignia NS-LDVD26Q-10A 26 in. HD-Ready...
Hi I cannot find the dvd eject button on my sony bravia. Can you please help me
All the new models of DVD player have no eject buttons. Its a safety feature to prevent the eject door from jamming or motor failing when somebody ejects the disc while the player is in a cabinet with a glass door. Also the logic is one has to approach the player to remove or insert the disc anyway !!!
May 29, 2011 | Sony Televison & Video
Dell Studio 17 Stuck Disc in drive
if you look close infront of the cd-dvd playerdoor there is a little hole if you stick a paper clip in there it will eject it.
Jul 10, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Panasonic dvd recorder model dmr-e55eb/ebl. played dvd,no problem - ejected dvd - green/blue colouring appeared on TV which disappeared when dvd recorder switched off. since then unable to play dvds. ...
This is a problem with either the logic or the power supply. Without seeing the machine and taking measurements inside, I can't state for sure the exact problem. These are decent machines. I would suggest that you bring it to an authorized Panasonic service center for a repair estimate. Post the results here and we'll suggest the next steps.
Dan
Apr 23, 2008 | Televison & Video
Phillips/Magnavox 26MD255V
manual eject button is on side were you load the disc
Nov 09, 2007 | Philips 26MD255V 26 in. LCD TV/DVD Combo
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
