Question about Irons
I have a Morphy richards steam elite 42221 the problem is that the water light comes on even when the tank is up to max. If I turn the power on and off the generator works for a short time then the light comes back on and the steam wont come out. We cleaned and emptied the boiler and it worked for a few seconds. Is there a sensor or blockage problem and can this be repaired.
  • 438 Answers
What did you use to clean your device ?
hard water can cause all sorts of troubles and this might be one of them, Yes anything can be fixed if you please
try strait vinegar in your unit, it will not damage and it works very well against hard water deposits that can cause problems like this, if this dose not work get back to me and we will try to find out what is the problem and make it right again
Posted on Oct 21, 2013
SOURCE: Tefal Pro Express Steam Generator doesn't.
OK... so I have fixed my problem of NO STEAM, just lots of water coming out of the iron press plate itself... I had already cleaned the boiler, so I tried adding 1/4 tsp - 1/2 tsp bicarbonate soda to the water and flushing it through. From what came out of the iron press plate, I would say the problem was caused by a build up of goop (technical term) inside the iron. Once cleared, the iron is steaming away again. Please note, u will need to have an old towel handy if this is ur problem, 'cos until it starts getting better, there is a fair amount of water coming out of the iron press plate. Just add the bicarb to the water reserve and use the steam buttons to bring the bicarb through. Do not attempt to iron clothing with the bicarb in the water!!! Carolyn ;)
Posted on Sep 20, 2008
  • 3 Answers
SOURCE: morphy richards steam generator model 42271
is there a noise when u press the trigger? if not there is sometimes a reset button on the front of the base. failing that the problem may well be the solenoid which opens to let the water into the steaming tank which is repairable but can be awkward.
Posted on Feb 06, 2009
landsend
  • 1066 Answers
SOURCE: Morphy Richards Jet Stream Elite
buy a new iron at Walmart for $20
Posted on Apr 03, 2009
SOURCE: Morphy richards jet steam iron.
my morphy richards steam genarator iron 42242 says it is hot enough but in fact sole plate is not and leaking water over garments.any ideas?email me t.hayward33@ntlworld.com
Posted on Apr 25, 2011
  • 910 Answers
SOURCE: Rowenta DG980 Expert Steam Generator Red
The problem will be with the level switch in the tank.
I've checked for a service manual without any luck and checked all the spares sites I know and there's no reference to a replacement level switch.
How would you be for opening the base and checking for loose or broken connections?
Posted on Jun 30, 2011
Steam generation minimum morphy richards
If tap water is used in a hard water area limescale can soon build up and reduce water flow into the steam generator.
A propriety descaler might help but if the situation is too advanced it is unlikely.
Mar 03, 2015 | Morphy Richards Irons
Water leaking from soleplate.....
Your Morphy Richards Jet Stream 42271 Iron is developing a leak. If the leak becomes worse, you may have to replace the iron.
Mar 05, 2018 | Morphy Richards Jet Stream 42271 Iron
Descale
Soak and/or run vinegar or CLR through it. They also make a steam iron cleaner.
May 11, 2013 | Morphy Richards Jet Stream 42271 Iron
Power steam elite boiler screw is stuck
Morphy Richards Power Steam Elite boiler screw
Mar 16, 2013 | Morphy Richards Irons
Irons Logo
314 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
