Question about Hotpoint Ultima WF860 Front Load Washer
Start switch pressed but machine does not start
  • 3,961 Answers
It is possible the motor start capacitor has failed. Unless you can test this, best call a service person.
Posted on Oct 20, 2013
Studio 166. How do I cancel toner display?
To erase the Toner symbol:-
Step 1:- Switch off the machine.
Step 2:- Press 0 and 8 buttons and switch on the machine
Step 3:- AD will appear on the display
Step 4:- Press 695 and then start button
A value either 1 or 0 will display
If it is 0 make it 1 and press interrupt button
If it is 1 make it 0 and press interrupt button
Switch off and on to check.
To erase the spanner symbol:-
Step 2:- Press 0 and 8 buttons and sitch on the machine
Step 4:- Press 251 and then start button
A value will appear on display
Press 0 now and then interrupt
Now AD appears on the display.
Press 252 and repeat the step 4
Press 253 and repeat the step 5
Switch off and on to sheck
Jan 05, 2016 | Toshiba Office Equipment & Supplies
The orange on/off button lights up. however the start/pause button does not.
It's hard to tell by the way you've phrased the question whether or not the button is doing what it is supposed to do, or if it is just the light indicator that is not working. So, I will answer both scenarios. // Press start button fully until you hear machine start; (usually less than one full second). In other words, hold button in until ''start'' is _heard_. After start has begun, holding button for 3 full seconds will ''pause'' the cycle. After ''pause'' pressing button again (just like first time) will restart cycle (i.e. ''take it off pause''). But while ''paused'' holding the button in again for any longer than a fraction of a second will cancel the wash. // TO CLARIFY: Press button for approx 1 second to start wash. After start has begun, pressing button for 3 seconds will ''pause'' wash. While ''paused'' pressing button again for less than a second (i.e. ''quick press of button'') will ''resume'' wash. Also, while ''paused'', pressing button for longer than a second (usually 3 seconds) will cancel the wash. // If the machine is (otherwise) working correctly, and your complaint is a light not lighting, then it is just a bad LED light. Best bet is leave it alone. Or, you could buy a new switch if the LED is _inside_ the switch. If the LED is on the control panel, then do yourself and big favor and don't mess with it.
Aug 15, 2015 | Washing Machines
Lid is not locking properly, washer sensor is overfilling, and the washer wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Apr 28, 2013 | Whirlpool WTW4950XW Washer
I did try: change fuse as first it was without any lights. Then checked sockets. It started again by itself. Then I reprogram it-switch off-turn on 90'C-press start button- switch on- keep pressing f
Try this reset, it may work:
-Turn Off power switch
-Select 90 degree washing
-Press and hold Start
-Turn ON power switch and keep pressed Start button 10 sec
-Depress Start button
-Turn Off power switch and turn On again and thats it...
Credit to original poster :)
Oct 19, 2012 | Washing Machines
F 14
counter problem
1- switch the machine off
2- key { 0 } + { 8 } together & switch it on .. keep pressing ( 0 + 8 ) for 8 seconds
3- will see a new menu .. key [ 389 ] then [ start ]
4- key [ 388 ] then [ start ]
5- restart the machine
Jul 05, 2011 | Toshiba E-Studio167 Copier
Does not start
Hi, Does not start as in you plug the machine in at the wall and switch it on and it wont start? or as in the machine turns on but pressing the start button wont start the machine? If its not starting when you switch it on at the wall then in all probability its your main controller module that has blown. Replacing the module will incorporate a great deal of money as any power supply would for any appliance due to it being the heart of the machine.
In the case that the machine turns on but wont start when pressing the start button indicates to me that the machine may have a problem with its display module which in turn will cost a great deal of money being the brains of the machine either way its going to cost a great deal of cash
Also try inspecting the main switch board it may be that the fuse has been tripped due to overload from other appliances, hope this helps
Apr 30, 2011 | Kenmore Dishwashers
Child lock is stuck on and machine won't start
Does this help?
If you wish to prevent small children or pets
from climbing into the machine, you can
deactivate the automatic door opening
function.
1. Turn off the machine using the main power
switch.
2. Press the Door Open button while
simultaneously pressing the main power
switch. Release the buttons.
3. Press the Key button and the red field goes
out. Automatic door opening is now
deactivated.
4. Press the Start/Stop button to save the
setting.
If you want to reactivate the function, follow
the instructions above, but when you press
the Key button (point 3) the red fields light up.
Store the setting by pressing the Start/Stop
button.
Do let us know if it does
regards
Feb 01, 2011 | Asko W640
My Xerox Workcentre-5020 machine showing U4 error. How can I solve this problem ?
@basanta711, Press 0 for 5 seconds then press green (start) then 50, green, 20 green, 0, green then on/Off the printer........... problem is solved
Nov 07, 2010 | Cell Phones
Getting error code E03-40. What does this mean?
E03-40 - faulty toner density sensor try the following press function the original size then 3..... your screen should display f1 service mode then press 8 then start now you should see f8 ..... now press start and scroll down to option 09 and press start now you wait till machine runs the process... after that you need to switch the machine off wait 1 minute and switch it back on
Jun 04, 2010 | Panasonic Workio DP-3520 Copier
Our machine's digital display reads 'dE' seconds after pressing start and nothing isour machine's digital display reads 'dE' seconds after pressing start and nothing is happening except for an awful b
The dE error means that the door switch has failed to "make" Either the door is not closed all the way, or the door switch needs to be replaced or adjusted.
Apr 18, 2009 | LG WM2487H Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
