Question about Canon PowerShot S100 Digital Camera
Cant delete files sd - Canon PowerShot S100 Digital Camera
Sd card
You have taken video and your tablet has stored the files on internal memory. That memory is full. You will now have to delete old videos or get a SD card to store new videos.
Feb 16, 2014 | Vizio Tablet VTAB1008
I cant figure out how to delete the videos off my camcorder now that I have downloaded them to my computer. I have some on the hard drive and some on the sd card.
Please make sure all video files have been transferred in computer then use Format option to delete all movie files in hard drive of camcorder, apply same procedure to sd card in camcorder.
Format option would be available in settings/ set up menu of camcorder.
Thanks.
Jun 17, 2011 | Panasonic HDC-TM80 Camcorder
How do I delete a stored game in progress on Harvest In The Heartland?
Select system settings, then select data management, Select the "System Memory" tab to delete files from the Nintendo DS system memory. Select the "SD Card" tab to delete files from an SD card. A list of saved files on the system memory or SD card will appear. Select the saved file you want to erase from the list. A prompt will appear.
Choose "Delete" from the prompt and confirm you want to delete the file. The saved file will be immediately erased from the system memory or SD card of the Nintendo DS.
Feb 18, 2011 | Destineer John Deere Harvest In The...
HOW DO I DELETE FILES
deleting files on sd cards is the same a deleting any other file on a computer as long as the media is not protected against file deletion or file altering
usually sd cards as you used to find also in old floppy dics, have a tab or switch you need to set accordingly to allow file overwriting. inspection the sd card and make sure that the tiny switch or lock is in the off position, reinstall sd card in the reader or sd card drive and attempt to delete files by selecting them and hitting the del key or simple selecting them and right clicking to then select delete.
if the tab is in the off position try it in the "on" position and see if deletion can be accomplished. if neither works your sd card may be defective. contact the provider and have the warranty honored accordingly in within the warranty terms.
May 06, 2010 | PNY 4GB Secure Digital High Capacity...
Cant save emailed photos to my g1 gallery
hello you just simply need to install an app from the market one called es file explorer and another called astro you will be able to delete files with es file explorer if necessary.
Aug 16, 2009 | HTC G1
Cant format sd card from ppc
you need this software https://kb.sandisk.com/app/answers/detail/a_id/2399/~/sandisk-secureaccess-3.0-support-information-and-download-page might be locked.
Feb 21, 2018 | LG CHOCOLATE VX8500 Cellular Phone
Downloaded files wont delete
Hi.. If the files were loaded to the SD card directlt from your computer via a card reader, try deleting them while in Safe Mode.If loaded directly to your phone, check if there is a setting on the phone or on the file properties to protect the files. If so, adjust it as needed, then attempt to delete the files again.
Jan 20, 2009 | SanDisk 2GB microSD Memory Card
Cant get games to play on micro sd card for m3 ds lite
plug in the sd card and there should be 2 files of the game the nds and sav delete the sav file and it should work
Dec 24, 2008 | Nintendo DS Lite Console
HP IPAQ POCKET PC
1st approach (Quick one!)
1. Soft reset your device
2. make a backup copy of the folder \SD-MMCard\MSMETADATA if exists.
3. delete the folder \SD-MMCard\MSMETADATA.
4. Soft reset your device once again.
2nd approach (Long one!)
If 1st approach did not work, restore the MSMETADATA folder and try the following:
Step Zero: BACKUP
- Make a full backup of your device (including storage cards). If you don't like to do a full backup keep at least a backup of all files and folders we are going to delete as indicated below:
Step One
-In the main device directory delete the file WMPInfo.xml
-Delete the \Application Data\Microsoft\Media Player\ directory and all of
the files in it including the WMDRM folder.
-Delete the \Music folder
Step Two
-Go to your SD card main directory and delete the file WMPInfo.xml
-Delete the folder \SD-MMCard\MSMETADATA
-Delete the folder \SD-MMCard\WMDRM
-Delete the folder \SD-MMCard\Music
Step Three
-Repeat step two for any other storage cards.
Step Four
-Refresh devices in WMP and the storages card should show up in the left tab
and in the sync window you can click "Next Device"
Hope this helps...
Feb 25, 2008 | HP iPAQ rx1950 Pocket PC
Canon PowerShot S100 Digital Camera Logo
14 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
