Question about LG WM2277 XL Front Load Stackable Washing Machine with 7 Washing Programs in 3 Colors ....
Detergent tray has too much water @ end of cycle...
Detergent tray now has a lot of water in it @ the end of the cycle. it has gotten worse over the last few months and i have to empty it after every load. have already done a sanitation cycle with vinegar twice, and a week later a sanitation cycle with bleach.
  • 1,294 Answers
Try pulling out the tray gently. Your tray is clogged with detergent which you have to remove with a tooth brush or something.....minor problem u have.
Posted on Sep 30, 2007
The fabric softener tray is flushed between cycles to remove residue.
Nov 10, 2017 | Washing Machines
Detergent dispenser tray not draining water after cycles
I have the same problem and sometimes water stays in the detergent tray as well. I don't have a solution other than to remove the whole tray and drain in the sink after each cycle.
Sep 09, 2009 | LG Washing Machines
After washing clothes, water stays in the detergent tray.
Best plan is probably to take the detergent tray right out of the machine, then take it to bits before washing it out with hot running water and a toothbrush.
The problem with these things is that the bit that blocks up is pretty well hidden until you dismantle the tray.
Jan 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bosch 300 Nexxt won't use detergent on cold cycles
Make absolutely sure you have the hoses connected to the correct inlet valves,it sounds to me as though they are the wrong way round.
Plz rate my solution.
Dec 29, 2008 | Bosch Nexxt 300 Series WFMC2201UC
The softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
Dec 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing cycle starts and takes hours even for short cycle.
Try checking for good water supply.
Pull out detergent tray and check for good water supply during filling.
if poor filling-
Try checking the hoses.
Turn taps off, disconnect from machine, place hose end in sink, turn tap on and check for good water flow.
if the hose has a red indicator in the side of the hose (end which is fitted to the tap) - Red indicator is a failed hose.(for models with Water Stop hose type "B")
Oct 05, 2008 | Whirlpool AWM6120 Front Load Washer
Detergent doesn't drain
The rod which controls the flow of water to the various compartments needs to be adjusted. It is not a difficult fix. You can contact Malber usa ( and they can "walk" you through it. In the alternative, you can put the detergent in the pre-wash tray without concern.
Sep 19, 2007 | Malber WD1000 Front Load Washer/Dryer
Water in detergent dispenser
Remove dispencer again, remove conditioner syphon assembly and clean up the little tube. Should then go okay
Jul 06, 2007 | LG WM2277H Front Load Washer
Washing Machines Logo
271 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
