Hotpoint wm72b Pressing start switch but does not work
  • 3,961 Answers
Does it fill with water? If so It is possible the motor start capacitor has failed.
If not a thermal fuse may have failed. Unless you know how to test all this, call a service person.
Posted on Oct 20, 2013
My hotpoint freezer fza84 light is on?
Meaning it is on when door is closed, how do you know? Generally there is only one reason, the pressure switch is defective, and they pop out easily, so pressing it manually will disclose if switch is faulty if lite does not turn off and on while depressing, sometimes you can fix switches by cleaning contacts.
FREE-PPV.com
Jun 03, 2015 | Hotpoint Refrigerators
Hotpoint Aquarius WD440G
Unplug the machine from the wall for 5 minutes, then plug it back in and try it again. If the lights come back, the control board needs to be replaced.
Jul 28, 2017 | Hotpoint Ariston WD440G Front Load...
HOTPOINT WF840P SHOWS TEST IN DISPLAY AND WILL NOT OPERATE
turn on while pressing the on and start buttons at the same time until 'dOFF' appears.
Feb 24, 2009 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint ultima super silent displays 'test' but dnt run cycle
its in factory test mode, this can be set by pressing the on and start buttons together. to reset, turn on while pressing the on and start together until dOFF appears
Jan 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Function buttons do not work on off button does
I have expreienced the same problem and carried out a hard re-set by holding down the on/off switch whilst pressing the program button. It's now working - but not sure for how long!
Jan 06, 2009 | Hotpoint 23 in. BFI68 Built-in Dishwasher
Hotpoint TDC32 keeps switching off after a short while
Yes, it sounds like the relay is the prob
It is located at the top behind the console panel.
It is a clear plastic covered box about 3" long, and held in place by 2 screws.
Changing this should solve the prob.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint TDC32 Electric Dryer
Washing machine wont start - close door message
Hi.
Most likely faulty door lock or door catch.
To access it, remove the clamp from drum front seal, and remove the seal from the front of the cabinet, undo the 2 screws that secure the door lock, and remove.
To test wether the lock is faulty or not, put a link wire across the (L) and (C)
connections on the lock, the m/c should now work, if it does not, then you have
a more serious problem.
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
How do i fix mo hotpoint wf740 when it says test
turn the machine on while pressing the on and start buttons at the same time until dOFF appears
Aug 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf 250 aquaries
try changing your water valve this should sort problem
Jun 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Still not working. Any one with any ideas how i can get it working again.thanks
Bad main control board,and fixing the board will only be a short fix.Sorry!
May 11, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
