Question about Logitech 250 Headset
Seems wire is loose at mute button - if you wiggle it the sound goes in and out.. was fine before?
Eclipse avn 5435 deck plays fine but once in a blue moon no sound comes from it. Only using rca on unit, gps works fine. I unplug all connectors and then works fine.
Jess, do a wiggle test on cables when you have volume, wiggle wires one at a time to see if sound goes out or static.
press the helpful button
Feb 07, 2016 | RCA Car Audio & Video
Why does my radio keep going off and on? Then later on, it works just fine. I can hear like a little buzzing sound when it goes off and on.
It sounds like a loose connection. It could be a loose connector or a broken wire. You'll have to take the radio out without unplugging it and with it on, give it the old wiggle test.
Feb 20, 2015 | Mercedes-Benz C-Class Cars & Trucks
2005 Ford Focus is dead until I wiggle the battery wires
A ground wire that is not grounding, until you wiggle the wires. Follow those wires, there is a loose connection in there. Start at the neg. battery post, clean and tighten. Follow the small wires you can wiggle, see any splices that may have started to pull apart? Find the ground screw or whatever the small wires use to ground, that may be loose. Maybe the small wire goes to that black box? Take it off and look for the ground that isn't grounding.
Aug 16, 2013 | Ford Cars & Trucks
I have a 95 Isuzu Trooper 3.2 DOHC. It just stopped running. Turns over have checked gas pressure seems fine. Thinking it's the crank shaft sensor. Where's it located.
Location is lower right side of engine block. ,you also have to remeber you have the famous ICM (ignition control module) This connector is famous for loose or corroded terminal, its located behind ICM at the intake manifold.wiggle it see if that will help to get it started,wiggle the connector you crank have your brother wiggle the wire to ICM and even the cranksensor wire3_29_2012_7_48_46_am.jpg3_29_2012_7_50_46_am.jpg
Mar 28, 2012 | 1995 Isuzu Trooper
My Radio dont work.....It plays dvds,cds just fine
has the radio ever worked since you had it put in? There is a chance that either the installers never reconnected your antenna, or it wasnt seated all the way and finally wiggled loose. Could also be mute wires are wired wrong.
May 15, 2010 | Pioneer AVH-P4900 Car Video Player
Starter has lost power when we wiggle wires truck will start..once turned off won't start again untill we re-wiggle wires. seems like the black housing that the red wire goes into is loose.
You have a loose connection on the starter or a grounded wire that causes a short. When you wiggle the wires you break the contact causing the short so it starts. Replace them and the problem will go away.
Oct 11, 2009 | 1999 Dodge Durango
How do you unmute a rip speed dv710 cd player, it seems to be stuck on mute.. im pressin the mute button but nothins hapenin??
my unit only muted when the engine was running it was on telephone mute or something (redphone at corner with cross thru it)to get the unit unmuted while the car (corsa B) was running i had to cut the brown wire labeled mute at the back i jst covered the bare wires with some tape and it worked fine
Jul 23, 2009 | Car Audio & Video
Hp pavilion dv9005us NO sound problem
you may want to check to see if the speaker wire is connected to the audio board. You'll need to remove the Keyboard, palm rest, etc. It should be located toward the front of the LT.
Jan 06, 2008 | HP Pavilion dv9000z Notebook
Television
please check if no audio is there. 1 speaker & its wire for loose. 2 check supply to audio section 3 & also check for loose contact in audio section. 4 signal coming to ic from sif section. 5 audio ic. good luck.
Sep 28, 2007 | Televison & Video
Logitech 250 Headset Logo
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
