Question about LG 42PC1DA 42 in. Plasma HDTV
TV LG 42PC1DA have the standby light in white color and TV don't turn ON nothing is responding. Some one have an idea to fix it ? maybe the YPSU-J011A power supply ? some capacitor are swollen ! Thx
    Top Expert:
  • LG Master
  • 74,383 Answers
You have to check its main digital board. It is a very skilled work. Contact any service technician. If you're sound in electronics and if you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Posted on Oct 20, 2013
  • Hideki
    Hideki Oct 20, 2013
    thx but my probleme isn't showed. My TV don't turn On when i push the ON/OFF button (juste the standby LED is shining in white when i put the 220Volts but normaly this LED is RED...
  • 135 Answers
SOURCE: Lg 42pc1da plasma tv wont turn on
will be a fault with either power or y-sus x-sus board is the tv still under warrenty if so request repair
Posted on Jan 18, 2009
  • 5 Answers
SOURCE: LG LCD 37'' standby problem
if you want i will buy the tv from you
Posted on Feb 23, 2009
  • 197 Answers
SOURCE: tv won't turn on - power SUPPLY OK
bad main pcb
Posted on Jun 07, 2009
  • 12 Answers
SOURCE: 42" LG 42LC2D HDTV Will not turn on
Hi, sounds like a power supply problem, most likely needs capacitors replaced, costs about £5 to do it yourself, and a fortune in the repair shop, easy enough if your handy or know someone who is,its worth a try,it'll be going in the bin anyway, cam
Posted on Jul 14, 2009
pjhislay1
  • 822 Answers
SOURCE: lg 32lx2r-ze tv won't power
needs new caps on power supply.........easy fix...
Posted on Feb 10, 2011
I have a LG 47ln5400 and when I press the power button the tv screen flashes white really quickly then nothing shows up on the screen. The red status light turns on and stays a solid color. Then when I...
First you have to check if the back light of the panel works fine . if it's okay ..
Then probably you have a problem with the T-con.
It's a small board at the back bottom side of the panel . Connected to the main board by means of LVDS cable .
Aug 05, 2017 | LG Televison & Video
LG 42PC1DA one day i was watching tv and the picture just went completely black still have sound, switches on and off as normal but the screen is blank, can anyone please help?
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.
Apr 01, 2012 | LG 42PC1DA 42 in. Plasma HDTV
My LG 32LD320 won't turn on. I have no standby light and have even tried changing the fuse. Help please!
If total dead best way is to follow the AC voltage from power cord inside the set to see where voltage is lost.
Also , were you having any problems having to turn set on several times to get it on?
Mar 20, 2012 | LG 32LD320 32 HDTVReady LCD TV
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
Very light colored verticle (1" wide) ribbon on LG 42" Plasma TV
The TV is design for 16:9 format. The bars appear when the TV off showing that the TV has been watching under channels which is have 4:3 format for long time. The screen was burn out because no sweepping to those area. This is not critical problem but you can do nothing to fix it. To eliminate it a bit you shoud read the manual, I believe it has mentioned how to roll or sweep the screen. For plasma TV, if you keep watching 4:3 channels fomat, you shoud do it one a month within 30'. Good luck
Aug 12, 2009 | LG 42PC1DA 42 in. Plasma HDTV
Jan 17, 2009 | LG 42PC1DA 42 in. Plasma HDTV
Nov 17, 2008 | LG 37LC7D 37 in. LCD HDTV
LG 42PC1DA 42 in. Plasma HDTV Logo
85 people viewed this question
Computer Repairing
Computer Repairing
