Question about BMW K1300S Cover, thermostat housing. Radiator
How to chang gearbox oil in k1300s - BMW K1300S Cover, thermostat housing. Radiator
I am trying to change my gear box oil and I can't find where to put the new oil into
There is a hole on the side of the gearbox that generally has a large hexagonal socket hole in it. You remove that fill plug and fill it until it starts to dribble out of the hole.
Google
year make model change gearbox oil
and look at the video tab.
2015 honda civic gearbox oil change Google Search
Oct 07, 2017 | Cars & Trucks
Does a 2011 caddyTDi250 1.6 ltr need the gearbox oil changed when the vehicle has its regular service?its 5 speed manual gearbox,and is there a filter to be changed?
No but check with the dealer or your service/owner manual for the manufacturer recommended gearbox oil change periods.
There is no filter on the manual gearbox .
Whatever the manufacturer recommended period is for a gearbox oil change, change the gearbox oil twice as frequently as recommended to maintain it in good condition. If, for example, a change every 50000 miles is stipulated then do it every 25000 or so.
Nov 02, 2015 | Cars & Trucks
How to change gearbox oil for CF Moto V5
Most modern motorcycles don't have separate gearbox oil.
The gearbox is lubricated by the engine oil hence the reason for regular oil and filter changes to be made following the manufacturers recommendations.
May 12, 2014 | 2008 Qlink Legacy 250
Gear shifting problems in Honda Prelude with Automatic transmission only when gearbox is cold
While just change ATF oil or CVT oil in transmission & old filter too. your car problem will be solve....
Nov 21, 2013 | 1998 Honda Prelude
What will make my 2001 honda rancher 350 blow oil out of the engine vent tube?
Compression, getting past the piston rings, is what actually forces the oil out. But fuel is in the compression blowby right along with air as the compression goes into the gearbox. The fuel mixes with the gearbox oil and actually increases the amount of fluid in the gearbox. Too much oil/gas in the gearbox puts the "oil" level much closer to the vent and promotes the oil leak. The proper fix is to do a top end job costing around $750 at the shop. The ******* way is to change the oil more frequently and maintain the proper oil level between oil changes. The cost of oil should be a bit less than the cost of a top end job..
Sep 05, 2011 | 2009 Honda FourTrax Rancher 4x4
Just need diagram on how to change transmission fluid
The VL1500 has a integral gearbox, it uses the same oil supply as the engine. Once you drain the engine oil you will be changing the gearbox oil. Suzuki's are not like Harley's with a seperate gearbox, also it will pay to use a good quality oil filter.
Nov 06, 2009 | 2001 Suzuki VL 1500 Intruder LC
Drain and refil gearbox oil on toyota conquest 1990
Here is a link to a step by step instructions on how to change the gearbox oil. If you don't want to change it, go to the refill portion of the instructions.
Fill it until the gear oil starts to run out of the fill hole.
http://toyotaownersclub.com/forums/index.php?showtopic=101692
Oct 05, 2009 | Toyota Corolla Cars & Trucks
Gearbox oil change
There should be a drain plug either on the bottom of the gearbox or on the side of the gearbox at the bottom. Put in fresh 10w40 motor oil. There will be an oil fill screw either on the left or right side of the gearbox case.
Apr 28, 2009 | 2005 Hyosung GT 250
What oil do i use
synthetic 30 weight is the proper oil
Dec 25, 2008 | 2005 Honda CRF 450 R
Transmission
Well, I'm not sure. Try changing the gearbox oil and try again. I saw on the other postings that most Audi gearbox problems pointing to a gearbox swap can be solved through oil change. I just had mine changed and it has reduced sluggishness and shuddering at low temperatures (from cool engine). It's a special gearbox oil you need to get from Audi, by the way.
Jun 14, 2008 | 2001 Audi A6
BMW K1300S Cover, thermostat housing. Radiator Logo
Top BMW Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
greg benton
Are you a BMW Vehicle Part and Accessory Expert? Answer questions, earn points and help others
