Can't log in - Computers & Internet
    Scholar:
  • 28 Answers
I don't know if the problem you are having is with one web site or several but if just one web site is affected then you should be able to find your way to the section of the login screen that helps with logging in ... it usually says something like "I can't log in" or "I forgot my password".
Try going through their process for resetting your password. If that doesn't work (the web site itself might be experiencing problems) then your next step is to contact the company support department either through email, chat or phone. They may be able to provide additional insight about current system problems or simply handle the password reset for you.
A few other things to consider ...
A virus might cause a problem with accessing or logging in to a web site. Run a complete system scan if you haven't done so in a while.
If you are running Microsoft Windows, your Hosts file could have been compromised. You'll need to do some research to learn more about the Hosts file. There are plenty of online resources that will teach you everything you need to know ... it is too complex of a subject to cover here.
Try switching temporarily to a different DNS. OpenDNS and Google are two good alternatives to your ISP's DNS.
Did you recently install new software? This could be especially important if it is anti-virus or anti-malware software as they sometimes conflict with network operation. If so try uninstalling the software or doing a Windows Restore to a restore point created at a time before the software was installed.
Temporarily disable your firewall - especially if it is not the default Windows firewall.
Reset your router. I don't mean just power off/on - push the reset button if there is one. Keep in mind that this will also reset the wireless password and the router control menu password so make sure you know how to access the router configuration menu to set those things back up if you do a reset.
Posted on Oct 20, 2013
2log(base4)x + log(base4)3=log(base4)x-log(base4)2
It is easier to use the rules for logarithms to clean this equation before trying to solve it. And the calculator is no help here.
Let me represent the logs as follows log b in base a = log(a,b). The first argument is the base.
2*log(4,x) - log(4,3)= log(4,x)- log(4,2)
Here you have two similar terms 2*log(4,x) on the left and log(4,x) on the right. Gather them both on the same side, say the left. You have
2*log(4,x) -log(4,x) +log(4,3) = log(4,x)-log(4,x) -log(4,2)
which is equivalent to log(4,x) +log(4,3) = -log(4,2)
Gather the constant terms on the right, and use log(a) +log(b)=log(a*b)
log(4,x) = -log(4,2) -log(4,3) = - { log(4,2)+log(4,3)} = -log(4,2*3)
You get log(4,x)= -log(4,6).
Take the constant term to the left, while changing its sign in the process. On the right remains 0, which is also the log of 1 in any base So log(4,x)+log(4,6) =0 =log(4,1)
Use the rule log(a) +log(b) = log(a*b) valid in any base, to obtain
log(4,6x)=log(4,1) which is equivalent to 6x=1. The solution is x=1/6
There are a few other shortcuts to get the solution but I preferred to take a pedestrian, step by step, approach.
Hope it helps.
Nov 25, 2009 | Casio FX-300MS Calculator
I need help with a change of base formula problem.
It's simple here some logs:
log x base y = log x / log y
log (x*y) = log x + log y
log (x/y) = log x - log y
you just need to know that the default base of log in calculators is 10, so log x mean
log x base 10 = log x / log 10,
so write log x / log y for log x base y example:
log 8 base 2 = log 8 / log 2 that is how you write it on calculator, hope it was helpful
Jul 01, 2009 | Texas Instruments TI-83 Plus Calculator
How do you input a logarithm base into the ti83 plus?
You can't it's default 10 so learn this logs:
so just divide the logs
hope it helps
Jun 28, 2009 | Texas Instruments TI-83 Plus Calculator
How to calculate
It's very simple: the calculators have a default base 10 so that log x it's log x base 10 so here is some logs:
Hope it's helped
Apr 09, 2009 | Sharp EL-520WBBK Calculator
To solve the problem using log
Look the calculators has a default base 10 and you can't change it but you may learn this:
so instead input log 8 base 2 you need to input log 8 / log 2
your example answer is about 0.919... if i get right what did you write.
Glad to help :)
Feb 21, 2009 | HP 33s Calculator
Find log(1-.2)
I don't get it but here some help with logs:
log x base y = log x / log y (when log x is default base 10 in calculators) and
the bases is default 10
hope it's helped
Feb 05, 2009 | Casio FX-300MS Calculator
Logarithmic functions
All calculators it's the same:
the default base in all the calculators is 10 so instead of writing log 4 base 2 you simply need to write log 4 / log 2
Hope you understand :)
Dec 16, 2008 | Casio FX-7400G Plus Calculator
Using logs
Here something that would help you:
so log 24 base 2 it's log 24 / log 2 etc.
and if i get right what you wrote x= 10 ^ ( 3 * (log 5) ) if no inverse it it's easy really Hope it's helped you.
Oct 23, 2008 | Casio FX-260 Calculator
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
