Question about Chrysler pt cruiser camshaft. exhaust. . camshaft & valves; camshaft
Can anyone tell me where to find the camshaft sensor on a astra van 04 1.7dti I can't find it I've been told it's on the top of the engine but can I hellas find it. getting stressed pls help.
I believe the camshaft sensor is in the distributer
Posted on Oct 20, 2013
Can anyone tell me where the camshaft sensor is on a 01 Mazda MPV mini van 2.5
W age of car..hard startn cud be a tuneup issue..bad dist cap..plug wires..fuel pressure reg or pump..git a data stream run w a factory scan tool....at a private shop only...for correctness n detail
Apr 22, 2015 | 2001 Mazda MPV
Astra owners club
Re- check the valve timing and ensure it is correct.
Hope that works.
Mar 03, 2014 | Cars & Trucks
Valve timing on Astra 1-3cdti 07
Here is the detail and diagram of your Astra 1.3 CDTi
Dec 16, 2013 | 1994 - 2001 Lexus ES300 Engine Timing Belt...
My check engine light and vsc trac and off lights have come on ... I have been told its the camshaft position sensor ... Can anyone confirm ???
The engine light is telling you that the CPU has found
sensor/s outside set parameters during the checking process. Have the fault codes read before wasting time and money guessing what has failed. Replace with
genuine items only as aftermarket units are not always compatible with the
settings in the CPU.
May 05, 2013 | Cars & Trucks
Where is the temperature gague sensor on a 2002 vauxhall astra envoy van?
The gauge sensor for your motor should be on the top of the fuel tank
May 15, 2012 | 1987 Vauxhall Astra
Car won't start
The camshaft sensor on this engine was located on the passenger side of the engine. You will need to remove the serpentine belt, and you can get to it by removing the inner fender or splash guard and get to it that way. I went down from the top. There are two sensors, one is a CRANKSHAFT sensor and other is a cam sensor. Make sure you know which is which. The crankshaft sensor is at the bottom of the engine, the camshaft is right by the water inlet. It is held in by 1 or 2 bolts. If your car is throwing the code for the camshaft sensor, just a heads up. I replaced the sensor and the sensor detects magnets installed on the camshaft. The engine kept throwing the code and came to find out one of the magnets had come off the end of the cam. I am telling you this just in case you go through the replacement and still end up with the code. the camshaft sensor is not too hard to replace, it's tight but it can be done. unbolt the old and bolt in the new. Make sure you disconnect battery before tackling this project. Hope that help some..
May 29, 2009 | 1991 Buick LeSabre
Second time complete breakdown of engine ,camshaft chevy venture
youve already got way too much money in that van,
go buy somthing else !!!!!!
Apr 17, 2009 | 1997 Chevrolet Venture
BMW 318 si 2002 engine cuts out
i had the same problem and it was infact the timing and chain tensioners
Feb 27, 2009 | 2002 BMW 3 Series
Location of camshaft position sensor on a 2001 Hyundai Elantra wL
The camshaft position sensor is located on the engine near the timing belt cover and under the upper radiator hose.
Dec 26, 2008 | 1998 Hyundai Elantra
Chrysler pt cruiser camshaft. exhaust. . camshaft & valves; camshaft Logo
Top Mopar Performance Vehicle Parts & Accessories Experts
Timllfixit
unosuave
Are you a Mopar Performance Vehicle Part and Accessory Expert? Answer questions, earn points and help others
