Question about Vector 995 Radar Detector
DIY Speaker replacement Bel 995
I have a Bel 995 and recently the speaker stopped working. I'm fairly handy and would like to do the repair myself, but I am having trouble removing the cover from the detector. I have only found one screw to remove, and when I remove it, I still can't get the cover off. Please let me know what else I have to do to open the detector? Thanks!
  • sschellato Sep 28, 2007
    Thanks! I found the other screw under a label at the bottom of the detector.
  • 150 Answers
Sometimes they hide the screws, usually under stickers/labels on the unit, remove all labels and if still no screws It's probably just a tight fit, unsnap by prying with flathead screwdriver. Good Luck
Posted on Sep 27, 2007
First you unscrew the single external screw. Next you turn the bottom plate left unscrewing an enternal screw locted in the south west corner of the device. Hope this helps.
Posted on Sep 03, 2008
SOURCE:
No sound on my vector 940
Beltronics is now using a special "high temperature" speaker which resolves issues with speakers blowing due to high ambient temperatures. Contact Beltronics and schedule service for your V940. Not only will Bel replace the speaker with the newer model, but they will also test and calibrate your V940 and install whatever the current firmware is for your V940.
Jun 22, 2009 | Vector 995 Radar Detector
Repair or replace?
If the rip or split extends from the voice coil out to the edge, the speaker may be too far gone to replace. I have repaired expensive speaker cones with epoxy cement, provided the tear is fairly small or narrow. No noticeable degradation of performance either.
Dec 20, 2008 | Infinity SM 255 Speaker
I have a beltronics 995 radar detector and i have a problem with it. The message "Service Required " appears.Please help . Thank you
This means that your RD has failed several attempts to self-calibrate its internal antenna. Like the message says, you must send in your V995 for service. Bel will fix whatever the issue is, and they will install the latest firmware too. Also, be sure to ask Bel to check and see if they need to replace the existing speaker with their new "high temp" speaker. The new speaker resolves potential issues of the original speaker failing due to high heat conditions.
Dec 03, 2008 | Vector 995 Radar Detector
No sound, voice or beeps
Good Day Joe,
Sounds to me like the internal speaker went, this is actually common on radar detectors. Although 9yrs is a lot longer than most will last. If you are handy with a soldering gun you can replace the internal speaker with a new one and get it working again. However be sure to take the unit apart before getting a new speaker so you can match up the size as it varies.
Good Luck and I hope thi shelps
Jul 04, 2008 | BEL 950 Radar Detector
BEL Radar Detector +
yes buy a direct wire kit this will fix your problem ccity sells them
Mar 20, 2008 | Vector 995 Radar Detector
No sound from the bel 880 radar detector
I have the same detector and my sound just went out, I called the number on the label on the bottom. They where very friendly and told me that it was more than likely the little speaker, they sell them for $8, if you are handy with a soldering iron its a simple task.
Nov 19, 2007 | BEL 880 Radar Detector
Bel 880 sound
Call bel, the number is on the label on the bottom, I am having the same problem with mine, he was very helpful and said it was probably the speaker which they sell for $8. If your handy with a soldering iron its simple repair. Or they offer a trade up service, giving you like $80 towards a new unit.
Nov 13, 2007 | BEL 880 Radar Detector
Internal Speaker type/rating?
The speaker is a 28mm diameter 32 Ohm speaker. Bel/Escort now use a newer custom PUI manufactured "high temp" speaker which resolves issues of the speaker blowing out due to high temperatures. Contact Bel/Escort using their online chat feature on their web sites. Likely they will send you a replacement speaker for a cheap price which you can solder in yourself (assuming that your RD is out of warranty).
Sep 28, 2007 | Vector 995 Radar Detector
Need Help with my radar detector
your speaker is bad more than likely,the heat and cold affect the little speaker and eventually fry it.you need to replace the little speaker.
Apr 30, 2007 | Pro RX65 Radar Detector
Vector 995 Radar Detector Logo
554 people viewed this question
Top Beltronics Vehicle Parts & Accessories Experts
Perry Mellott
Perry Mellott
Jerry Greenberg
Jerry Greenberg
Karl Kittsteiner
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
