Question about Dryers
CAMPOMATIC 402 DRYER WON'T SPIN - Dryers
Dryer won't spin or rinse completely and code dr apears
LOOKS LIKE A TIMER OR CONTROLLER BOARD REPLACEMENT
Jan 30, 2013 | Washing Machines
Duet sport electric dryer won't heat or spin, minute counter counts down
You will need to replace the "thermal fuse" located on the back of the dryer. Here is the part to order.
Nov 22, 2012 | Dryers
Dryer Won't spin
What is the model number of the unit?
Nov 10, 2012 | Washing Machines
Won't spin
The start relay on the motor is bad and you will need to replace the motor. The relay is not sold separate. Here is the motor you need to order.
Oct 30, 2012 | Frigidaire AEQ7000EG Affinity Series...
My maytag epic z dryer won't spin
Check the thermostat of your dryer first. If this does not work out, then please visit Clothes Dryer Element.
Oct 24, 2012 | Maytag Dryers
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Its a 400 series washer actually, and it will only spin very small amounts of clothes. It won't even spin a single sheet by itself??
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 10, 2011 | Kenmore 400 6942 Dryer
Dryer wont spin
About 90+% of the time when a dryer won't spin it is a broken/slipped belt.
If the dryer makes some niose when activated, then the motor is turning, which exonerates the
motor, leaving just the belt - the belt may have slipped off a (possibly broken) pulley.
Aug 03, 2011 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
52 people viewed this question
Top Dryers Experts
