Magenta is not clear please cleaning code - Office Equipment & Supplies
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 67 Answers
What is the printer brand and model
Posted on Oct 20, 2013
My Espon R230 printer has problem with Light Magenta colour, i bought new cartridge but then also light magenta nozzle check is not clear, i think it is printer problem, please help me how to solve it
First you could do a printer test. The printer will print a small pattern with all colours making it possible to check if and if so, what nozzle are blocked. Sometimes the cleaning cycle will help, but sometimes there is just some dirt under the head. Please don't try to remove it with tools if there is something. Just use a thick piece or printing paper to solve that problem. Please check the manual for details. Perhaps the epson site can help you with that:
http://www.epson.com.sg/sites/epson_singapore/support/support.page
Jan 12, 2015 | Epson STYLUS R230 InkJet Photo Printer
When I print a one-sided color image there is magenta toner on the back side of the printed paper.
This will be because there is a magenta toner spillage in your machine. It should clear on it's own but may need some help to get started on cleaning.
Grab a cloth something like a chux cleaning cloth and wipe up the toner spillage in the machine. DO NOT USE YOUR HOME VACUUM CLEANER.
Once you have most of the spillage cleaned up then run several pages through the machine to clear out any left over toner and it should be clear from then on.
Sep 16, 2014 | HP LaserJet 3600 Printer
My brother mfc j220 canoot print magenta color although on the display the magenta is full i clean many times but when i test print i didnt see dotted magenta. what can i do?
It looks like the magenta print head nozzels are blocked.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Sep 06, 2011 | Brother MFC 210C All-In-One InkJet Printer
"wrong cartridge"- Printer is giving us a "wrong
Hi Sherri
I am having the same problem with my MP780 mine started doing the same thingafter deciding to use Calidad inks the large black ink leaked into the yellowink (stick to canon inks).
What I have done so far with no success -
Replaced the ink cartridges with new ones supplied by Calidad, still the sameproblem.
Removed and cleaned the print heads manually and to my surprize after soakingin warm water and multiple cleanings for over 1hr black ink is still coming outof the yellow ink head.
I still get the same message after all I have tried...
One thing I did manage to do is prime the yellow ink and got it flowing throughthe head again but it's still mixed with black... I wonder if you may have runout of magenta and dried the head...
Try priming the magenta ink by removing the head (don't touch or wet the metalcontacts at the rear, the ink heads are on the bottom) place on a clean lintfree cloth (or I just used damp tissues then dry tissues) you should get onelong black strip and two cyan, two magenta and two yellow strips on the tissue,if you do not then try priming by replacing the magenta cartridge and gentlypumping the cartridge up and down repeat until you get the ink flowing.
Replace the head and cartridges, press ok, turn the printer off then reset.
Let me know if it works or if you come up with another solution that works as Iam still trying to figure out how to fix mine.
Good luck
Dec 21, 2010 | Canon PIXMA MP780 All-In-One InkJet...
My printer is not printing magenta. I have changed the cartridge (hp one), cleaned the print heads and
The magenta print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked magenta print nozzles. Also check the magenta cartridge, make sure it is not empty.
If none of this works then the print head needs to be replaced.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 13, 2010 | Computers & Internet
The magenta won't work. i put a new cartridge, cleaned headers, test printed. all the other colors work find but, NO magenta comes out.
This sounds like you are using an aftermarket or refilled ink cartridge. If this is the case, try putting in a new OEM magenta ink cartridge and running the deep cleaning utility 3 times. This usually clears a clogged nozzle caused by non-OEM loaded inks.
Let me know if this clears the problem. Thanks.
Sep 03, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Printer will not print Magenta or Photo Magenta
When you have an ink problem on one or more of the nozzles, the chances are that they have been clogged by either inactivity or the use of aftermarket/refilled ink. The first thing to try is to insert new OEM ink cartridges and run the nozzle cleaning utility at least 3 times to clear the nozzle. Depending on the clogging it may take more than 3 cleanings. This method should clear the problem. Be careful when you buy aftermarket inks since they may not meet the specifications required by the manufacturer. I can suggest some good vendors if you need.
Please try this solution as soon as possible and let me know the results. Thanks.
Feb 09, 2010 | HP Photosmart C6180 All-In-One InkJet...
Error code e000020-0021
getfile.asp?rid=1258 November 12, 2007 getfile.asp?rid=3215 Product : imageRUNNER C2880 / C3380 / C2880i / C3380i Title : E020-0021 Error :
E020-0021will not reset after the machine is powered off and on. Replacing the Drum and the ATR Sensor did not clear the error.
Workaround :
In this case cleaning the Dust Proof Glass fixed the error.Check the Dust Proof Glass for soiling.The glass is located under each unit and may have toner spilled on it. Clean the glass with the tool provided on the front door. Instruction's are also included there.
getfile.asp?rid=22945getfile.asp?rid=22948 Canon USA, Inc. Systems & Technical Support Division
Mar 18, 2009 | Canon Office Equipment & Supplies
Magenta colour comes through on all prints right across the page, it is faded but is still clearly there. I can temporarily fix problem by using the printer menu to clean the magenta developer, but it...
We have over 50 of these printers and a few have had the magenta bleeding problem. On everyone of them the problem was corrected by going to the clean developer function under Maintenence from the Menu and choosing to clean the magenta color. Usually have to run it a couple times but it has always corrected the problem so far.
Mar 29, 2008 | Dell 5100cn Laser Printer
11 people viewed this question
k24674
jasbo
jasbo
