Question about Dryers
Huebsch dryer troubleshooting
Error code AF -2 and drum is not turning.
SOURCE: error code AF Whirlpool cabrio dryer
I found the answer to the code AF also and it means the air flow is blocked. I checked my dryer vent on the outside and it was clear. However when I removed the dryer duct it was clogged just inside the machine. I had washed and dried a blanket that shed alot!
Posted on Jan 10, 2008
SOURCE: Kemore Elite Oasis Dryer Error Code "AF?"
Problem solved! We read on here about someone else addressing the AF code by removing the back panel and fixing the pully that had come off. Belt was fine, with pully back in place dryer now works perfectly again. Thank you for saving us so much time and money!
Posted on Jun 14, 2008
SOURCE: ''AF'' error on Maytag Bravos dryer
"AF" means "Air Flow". Your vents are cloged with lint. I have had to vaccum out my vents several times, both inside and out. It's been a bit of a pain.
Posted on Dec 27, 2009
SOURCE: AF Error Code
If thats not it, then you nay have a faulty sensor.
AF Restricted Airflow Condition
"AF" flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
Posted on Mar 18, 2010
Testimonial: "Thanks so much!"
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Electrolux E52 error code Dryer
    Hello drew_wedemey -Typically error code E52 indicates that the unit has a faulty motor. If the drum does not turn freely by hand, then I highly suggest contacting a professional to accurately diagnose the following; motor windings, L1 power supply voltage and the motor thermal protector.
    Posted on Oct 02, 2012
    Err message. What causes this?
    Owner's manual, troubleshooting. No manual, or lost, try
    manualslib.com or MFG website, or their customer service email.
    Apr 07, 2015 | Dryers
    Huebsch dryer parts
    www.huebsch.com/support/technical-literature
    May 23, 2014 | Huebsch Parts Huebsch H96382106 Dryer...
    could be door switch
    Mar 23, 2014 | Dryers
    Dryerstartsbyitself
    Hi check the door switch is set properly.
    Mar 07, 2014 | Huebsch Parts Huebsch 254P4P Washer HOOK,...
    It will not dry it say the lettrs af
    The airflow is restricted as indicated by the AF code. Check for clog lint filter and/or restricted vent system as lint build up in these areas cause airflow restriction and hence the AF code. Another possible reason is a faulty exhaust thermistor located on the blower housing. It is likely a thermistor fault if the lint filter including the vent system are all clear from lint built up but the AF code persists.
    Disconnect power then remove the rear access panel and locate the thermistor on the blower housing. Disconnecting the thermistor and running the dryer will cause E1 to appear on the display to indicate an open circuit thermistor and E2 if the thermistor wires are connected together. Replace the thermistor if this is the case. Click on the links below for additional troubleshooting information.
    Error Code E1
    Error Code E2
    Error Code AF
    Jun 18, 2011 | Whirlpool Dryers
    Kenmore elite model #110-67042601 is flashing a AF code
    The AF error code for Kenmore Elite Oasis dryers with model numbers 11067032601, 11067042601, W10035200, 11067032600, and 11067042600 indicates that the dryer is experiencing an airflow problem. The Kenmore Elite Oasis owner's manual recommends four troubleshooting solutions to an airflow problem: clean the dryer's lint screen, ensure that the exterior exhaust hood connected to the dryer is unblocked, ensure that the vent connecting the dryer to the wall is clear and see that the vent is cleaned professionally.
    Read more: Error Codes on Kenmore Dryers ' eHow.com http://www.ehow.com/list_7192588_error-codes-kenmore-dryers.html#ixzz1MuOgWsZC it is found also on this link above by clicking the link if you have any further questions please message me back and your dryer should be dlinted at least once per year to avoid dryer breakdown you can also see how to dlint your dryer by clicking this tip that I wrote http://www.fixya.com/support/r8732702-prolong_life_dryer I await your reply if you have any further questions Thanks Rick
    May 20, 2011 | Kenmore 72982 Gas Dryer
    AF error will not go away after cleaning vent and lint filters
    Thank you for contacting Fixya.com.
    AF is an error that will flash if a restricted air flow is sensed by the dryer control. If three consecutive cycles have low airflow the control will flash the AF error.
    The AF error code can be cleared by pressing the Drying Temp pad for 5 seconds while in stand-by mode. AF will flash in the display for 1 second then "on" will appear in the display. If you press Drying Temp again and "of" will appear in the display indicating the AF error display has been turned off. Try this procedure and see if the "of" error goes away. If the "of" came up in the display by itself then the keypad may be stuck. However After cleaning the dryer's lint screen, ensure that the exterior exhaust hood connected to the dryer is unblocked, ensure that the vent connecting the dryer to the wall is clear and see that the vent is cleaned professionally.
    Please get back to us if you have any further query.
    Nov 29, 2010 | Kenmore 67062 Dryer
    AF Error Code
    obstructed.
    Mar 18, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
    Jun 14, 2008 | Kenmore 67082 Electric Dryer
    Dryers Logo
    1,080 people viewed this question
    Top Dryers Experts
