Question about Aastra Telecom Aastra 55i IP Phone
Aastra 6755i boots up with a bad certificate error message. Can't make calls.
I have an LG Ultimate 2 an it just keeps flashing on an off saying, error : boot certification verify secure booting error, cause : boot certification verify. How do I fix that?
This requires more technical in person diagnosis. some things you can try are to boot in to the bios menu.
  • To do this you will have to watch as it is turning on and on one of the startup screens it will tell you to press one of the function keys (F10, F2,F12, and so on) click the one that says "bios" or "settings".
  • After that you will need to search through all the settings for something called the "IDE self test" run that once, it will take a while.
  • and lastly look for another option called the boot order. you have to make sure that the option that says hard drive is first.
I am sorry i can't be of more assistance but not much can be done without seeing the laptop.
Jul 06, 2015 | LG Computers & Internet
How do I remove the red flashing light on my phone?
probably means that you either have a missed call or message on your machine try deleting the call history and deleting all old messages. that might turn it off
Mar 24, 2015 | Aastra Telecom Aastra M9417CW 2-Line...
Aastra voicemail
This Depends on your providers system . If yo go and retrieve your messages and hit 4 3 2 2 this will get you to nowhere you can record a message for incoming calls. If you want to change you message for when some calls you and you are on the phone you would do the same as above but hit 4 3 2 1. That is where you change your "on the phone message" never put a date in that one. Just record " hi I am on the phone at the moment please lease a message at the tone" Hope this helps
Apr 26, 2013 | Aastra Telecom Aastra 9417CW Two-Line...
Activate message indicator light on
Call your provider and ask them to turn it on. They probably forgotto include that. If you pick up and there is a repetitive busy sound the company has you set for sadder. Tell them you have an indicator light hope this helps
Feb 07, 2013 | Aastra Telecom Aastra 8314 Corded Phone
I have a aastra 390 phone, the message light keeps flashing when no messages
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jan 27, 2013 | Aastra Telecom Powertouch/Vista 390 Corded...
Aastra 9110 message light doesn't light
were you able to get this working? hat did you have to do?
Dec 07, 2012 | Aastra Telecom Aastra 9110 Single Line...
Aastra 8004 Message light constantly on
Sent yourself a message from another phone then delete it with 3 3 7. That should do it
Aug 08, 2012 | Aastra Telecom Aastra 8004 Basic Telephone...
I am having problems connecting VPN Connection on my Windows 7, it says there need to be a machine certificate installed before i can connect using L2TP/IPsec. error code :766
"Error 766: A certificate could not be found. Connections that use the L2TP protocol over IPSec require the installation of a machine certificate, also known as a computer certificate."
"Error 766: The L2TP connection attempt failed because the security layer could not authenticate the remote computer."
Cause: Connections that use the L2TP protocol over IPSec require the installation of a machine certificate, also known as a computer certificate. You will see this error message when such a certificate is not available.
Typically, this error is generated on a remote access server that has active L2TP ports configured, the remote access service started but there is no certificate in the computer certificate store. This generates an event log message that tells the administrator that L2TP ports will not be able to accept calls until a certificate is acquired and RRAS is restarted.
Resolutions: 1. If you use PPTP VPN, select Automatic in Type of VPN.
2. If you use L2TP, check the remote access server and make sure there is certificate in the computer certificate store.
Sep 18, 2010 | Computers & Internet
How do I call forward this phone to my cell?
Forwarding is through the plan provider and part of the voice mail system.
Feb 08, 2010 | Aastra Telecom Aastra 9316 CW Corded Phone
Aastra Telecom Aastra 55i IP Phone Logo
413 people viewed this question
Top Aastra Telecom Computers & Internet Experts
David Payne
David Payne
Are you an Aastra Telecom Computer and Internet Expert? Answer questions, earn points and help others
