Question about Toshiba e-Studio120 Copier
Toshiba e-studio 202s copier/results for H4 error
  • 990 Answers
SOURCE: error code c440
Hello sir; C440in this machine,it means fuser unit problem, but it can be reset the procedure as follow;
1, hold down "0" and "8" keys while turn on the power.
2, enter 400 press start.
3, enter 0 press set or enter.
Posted on Jan 07, 2009
  • 10 Answers
SOURCE: Error code H4-00 and machine is "locked-up" in scan mode
go into service mode 05 400 set to "0" switch copier off than on
Posted on May 19, 2009
  • 628 Answers
SOURCE: Error code C380 paper feed failure
c380 indicates auto-toner error for black developer (K).
Check following:
Is the harness between the LGC board and the developer unit drawer connector open-circuited?
Is any harness inside the developer unit or the auto-toner sensor harness open-circuited?
Is the auto-toner sensor connector or the connector CN341 on the LGC board disconnected?
IF connector no problems, then u probably need to replace the auto toner sensor.
Posted on May 28, 2009
  • 990 Answers
SOURCE: Error F120
Hello sir; The error code you display F-120 it means "data base" problem it can not be reset you have to replace either memory chip or hard drive.
Posted on Jun 02, 2009
  • 66 Answers
SOURCE: error c44 call for service
C44-Heater abnormality after abnormality judgment: The temperature of the fuser roller has exceeded the range of control or does not even reach the range.
You can try going into (08) mode by holding 0 and 8 while turning on the copier. Once the copier starts up key in 400 and press start, input "0" and press interrupt. Try rebooting the copier, if this doesn't clear that call for service then you are going to need to get work done on your fuser.
Posted on Oct 04, 2010
Thoshiba e studio 120. What does error code H4 mean?
The Code H-4 Mean the copier needs to be reset. Also I have added a link to help you troubleshoot the copier.
Thread Toshiba studio 120 with error code H4
Mar 17, 2016 | Office Equipment & Supplies
How to reset Toshiba e-Studio 161 Copier Copier with "error code H4"
Step 1:-
Press
"C" key AUTO/TEXT/PHOTO key
"C" key AUTO/TEXT/PHOTO Key
(Note:Perform the first two key strokes quickly )
Machine display should stop blinking
Now press 14 and press start button.
Switch off and on to check
Feb 27, 2016 | Toshiba Office Equipment & Supplies
How do i fix my toshiba studio 202s,double image result
If you have replaced all that, check your drum cleaning blade and your erase lamps, these two items will contribute for Ghost images "double image". The erase lamps disperse the electrical charge so the blade can scrap the toner off the drum.
Dec 10, 2014 | Toshiba Office Equipment & Supplies
Error reseting h4 for toshiba
H4 is probably a fuser temperature code. Sadly the 161 is obsolete and parts are no longer being made. You'd be wasting money getting a new fuser for it. Time to upgrade.
Jan 04, 2013 | Toshiba E-Studio 161 Copier
MY COPIER INDICATES SYSTEM ERROR H4 00, HOW DO I CLEAR IT
H4 00 Heat roller low temperature detection.
The thermistor in the fuser is dirt. Clean it.
Jan 21, 2011 | Toshiba e-Studio 161 Copier Copier
Toshiba e-studio error H-4
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} H4 Heat roller low temperature detection
Apr 28, 2010 | Toshiba e-STUDIO 150 All-In-One Laser...
Error h4
H4 in 161, fuser low temp.; instantly solve it by simulation (c-auto-c-auto) 14; check thermistor; check fuser lamp by 5-02. it is to blink!
Jul 07, 2009 | Toshiba e-Studio DP170F Plain Paper Laser...
H4 is a fuser error. It needs to be replaced by a tech. Sometimes they can reset this error in service program.
Apr 24, 2009 | Toshiba E-Studio 3511 Color Copier
Toshiba e-studio 150, Problem H4
This is a fuser related error - the fuser is not warming up within a specified time frame. It could be the heater lamp or a thermostat/thermistor that is not working, possibly a bad fan. You can cancel the error code (hopefully the error does not come back) by going into sim mode. press the following keys one after the other "clear" "density select key" "clear" "density select key" then enter 14 and the copy start key. then restart the copier. If error code persists you could remove the fuser unit and look for any foreign matter inside the fuser. dirty thermistor or thermostat can cause this too.
Hope this helps
Apr 05, 2009 | Toshiba E-Studio 161 Copier
90 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
