Hello, i am using Haier washer dryer HWD-D1200TXVE that is 1 year old, after a full cycle (pre-wash) the machine gave an error 12 and did not perform drying because water was not drained. I opened the filter and emptied the water and found some debrits blocking the filter. After the water came out, i set the machine to dry, after 3 drying cycles, the clothes are still wet. knowing that the clothes are coming out warm but not dry. What is the problem ?? What shall i do??
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 83 Answers
Look up the mfg website and see if they have a troubleshooting page or a support group. It may still be a warranty item check that as well
Posted on Oct 20, 2013
5 Suggested Answers
  • 107 Answers
SOURCE: My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Posted on Mar 13, 2009
  • 714 Answers
SOURCE: haier xqg50 will not dry
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on Jan 11, 2010
obthomas363
SOURCE: clothes not heating up and remain wet
The HWD1600 dries by pulling air from the bottom of the drum through the condenser then heating it then discharging back into the drum at near the top of the door seal. Its my experience this circut gets plugged with lint. When it is plugged the hot air flow is reduced and the condenser water is delayed and out of time with the pump. The condenser water then builds up and get the clothes wet and so they never dry. Remove the hose at the bottom of the condenser and clean the lint from the condenser. You may need to do this more than once as lint tend to settle here and do its plugging.
Posted on Feb 20, 2013
  • 1010 Answers
SOURCE: candy washer dryer filling water dry cycle then empty
Could be the circuit board at fault
Posted on Mar 31, 2013
Haier HWD 1600, error 7
I had this washer for almost 2 yrs and you'll end up fixing things here and there. Well after some heavy research this error was supposedly the control box or some computer chip/loose connection. After taking apart all the pieces and reassembling, still err7 comes up. Turns out our daughter liked to open the door and pull down on it, causing a misalignment. There's lock that 'clicks' when you start a load to lock the door and I'm guessing there's a sensor that takes 5 seconds to detect if the door is closed properly. Our door was misaligned so the sensor tripped the circuit after 3 seconds of the water starting. I just press the door more with my knee and start the load. After 5 seconds I let go and all is well.
Apr 21, 2014 | Haier 14.3 lb. Washer/Dryer Combo
SAMSUNG TOP LOAD WASHER (ONLY 3 MTHS OLD) WILL NOT COMPLETE SPIN CYCLE. IT STOPS BEFORE GETTING TO FULL SPEED, REPORTS AN OFF BALANCE ERROR CODE. IMPOSSIBLE TO BALANCE - FROM TOWELS, SHEETS, REGULAR...
You could be having a problem with your hall sensor. I would recommend you call Samsung for a warranty service call. The machine should have a 1 year parts and labor warranty so let them fix it for free.
Sep 16, 2013 | Washing Machines
I have a haier hwd 1600 that is giving a error code 13 what does that mean and can i reset the machine or do i have to call a service tech
I service this machine before. There is no service manual for any Haier products.
You might want to change these parts out in the unit: Main PCB board, Heater Element, Thermostat and the Condenser.
Mar 25, 2013 | Haier HWD1600 13-Pound Combo Washer Dryer
I have a haier washer-dryer combo. washes and dries but it is making a loud clanking noise, esp loud during the spin cycle. draining well.
Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
Feb 12, 2013 | Haier Washing Machines
E12 eror on Haier washer dryier
Error 12 means Drainage error, water not emptied within 4 minutes
Solution:
Clean the fi lter and check the drain hose for blockage. If error still exists, please contact the Haier maintenance personnel.
Thanks and have a nice day.
Jul 03, 2011 | Haier XQG50-11 Front Load Washer / Dryer
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
Error code 7
The error code 7 is in fact a motor error.
The motor that drives the spin cycle has become faulty. The only solution now is to get an engineer in to fix it or get it sent away to get repaired.
Sep 08, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Detergent doesn't drain
The rod which controls the flow of water to the various compartments needs to be adjusted. It is not a difficult fix. You can contact Malber usa (info@malberusa.com) and they can "walk" you through it. In the alternative, you can put the detergent in the pre-wash tray without concern.
Sep 19, 2007 | Malber WD1000 Front Load Washer/Dryer
Washing Machines Logo
117 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
