Question about Gigabyte Computers & Internet
7vt600p-rz not detect hdd sata 3
Hi, I try to set new HDD SATA3 on my motherboard, but it doesn't detect. Before month I try with SATA 2 hard and motherboard detected. What can I do to solve this problem. Motherboard sais: Serias port - Not Detected of BIOS load
map9966
  • 2351 Answers
SOURCE: sata hdd detected but problem with booting&installation
When using a single SATA drive you need to set the Serial ATA Controller to [Enable] & set the M1573 RAID Function to [Disable] Page 2-24 in the manual.
Posted on Jun 30, 2008
Nic61
  • 1073 Answers
SOURCE: Drive SATA 3.0 Gb not detected by msi 7060
3GB Sata driver? i dident know there existed so smal drivers
Anyway, if your bios dosent detect the driver u probably need to update the bios drivers.
Go to MSI site:
http://global.msi.com.tw/index.php?func=proddesc&maincat_no=1&cat2_no=&cat3_no=&prod_no=158
Instal LIVE UPDATE and let msi check you computer for laterst drivers u need to instal
Posted on Nov 20, 2008
map9966
  • 2351 Answers
SOURCE: Sata Harddisk Not detected in Post operation
Hi vijjis,
Make sure your SATA drive is connected to SATA port 1 which is the bottom port. Double check both the data cable & power cable. The data cable only connects one way at the board & at the drive. Same for the power cable. Your SATA drive must be listed in the bios menu & you must list the SATA drive with-in the boot order. If your cabling is all correct & you still do not see the SATA drive in the bios menu than the onboard SATA controller is defective. This can not be repaired because it is integrated into the board. It will not hurt to clear the cmos. See page 15 in your manual. Your board can only run SATA 1.0 = 150MBs. If your Seagate is pinned for SATA II = 300MBs, change the jumper on the drive. (This may or may not work). See if the bios list the drive.
One other option, you can buy a PCI SATA controller.
Here are a few; http://www.google.com/products?q=Promise+pci+sata+I+controller&btnG=Search+Products&hl=en&show=dd
Link to Mercury P4VM800M7; http://www.mercury-pc.com/product-detail.php?link=p-mainboards&subtitle=Mainboard&productid=644#
Good luck vijis!
Thank you for using fixya.
Mike
Posted on Dec 11, 2008
  • 6 Answers
SOURCE: M2N-MX SE PLUS SATA PROBLEM
Do your have windows installed on a ide drive?, cos if this is the case you have to install the sata hdd drivers.
Posted on Mar 30, 2009
  • 108 Answers
SOURCE: sata hdd not detected
Yes, go into the bios and make sure that SATA is turned on. Sometimes with motherboards that have two ide controllers the SATA is turned off by default. Also another thing to check is whether the motherboard is SATA I or SATA II. If it is SATA I then change the jumper on the hard drive to peg back to SATA I. Your new hard drive is SATA II and the motherboard may not support it.
Posted on Jun 10, 2009
How can I use a SATA HDD in a 7NF-RZ motherboard? What cables/adapters are required?
Hey there. To install SATA devices on any motherboard follow these steps:
1- Make sure your Motherboard supports SATA, a 7NF-RZ works fine.
2- Install the HDD on your case, usually you have to screw it in or if you have a newer case you can lock it in place with a latch.(The SATA slots on a case are usually above the optical drive slots).
3-If you have another HDD already installed, and you don't want the new HDD to have system files, make sure it's designation is set to Slave. To do this, remove the jumper on the HDD pins(a white plastic connector) with tweezers, and, according to your HDD specifications, move it up or down to Slave designation.
4-Use a SATA cable from your Power Supply and connect it to the HDD, then, use a SATA adaptor cable which should have come with your HDD and connect it to the HDD, then to your Motherboard SATA adaptor(these vary from motherboard to another, so use your Manual to specify where it is).
5-Boot up your computer, and enter BIOS. Usually press either F2,F5,F12 or Esc. After that go to Auto-Detect drivers. When you're done, Save & Exit.
You should have successfully installed your new HDD!
Aug 21, 2011 | Gigabyte 7NF-RZ (GA-7NF-RZ) Motherboard
Hello, My my motherborad is ASUS p5rd1-vm;RAM1GB and hard disk is PATA 80 GB but the HDD is having some kind of problem and the windows have shown a warning about it several times. Now i want to buy a...
Yes, it's compatible with the motherboard, no, it's not compatible with the XP install disk because it doesn't have SATA support. And since Asus doesn't provides it special driver needed (one that must be put on a floppy) it means that you simply cannot install XP on this disk.
All you can do is to obtain another PATA hdd what ever its size and install XP in it. Then put the new SATA disk in and use it to store all the installed programs and all your files on it. As a bonus you won't lose them if the new PATA disk fails or XP gets corrupted.
Or install Vista or 7 instead of XP, the have support for SATA disks
Jul 28, 2011 | ASUS P5RD1-VM Motherboard
NOT WORK SATA HDD
when the system restart press del and go to bios in bios you have to click optimised defults then save and exit still the hard disk isnot detected then change the hard disk
Dec 30, 2010 | VIA Gigabyte GA-7VT600P-RZ KT600 Socket A...
Will this motherboard support 250 gb harddrive ide seagate
is it SATA? it shouldn't have a problem with hard drives unless the plugs are different. if the HDD is sata and you got a sata connection on your motherboard then you're all set
Feb 21, 2010 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Not ditect SATA HARDISK
Hi
I know what is problem,some of mother is made only SATA HDD data transfer rate 1.5 GB per second.Now all are SATA HDD data read rate 3 up to g GB per second .Follow the instruction label on the hard drive.
If you use your Motherboard 3GB data read hard drive you can customise setting jumper source of data rate 1.5 then MSI Motherboard detect SATA hard drive.
Good Luck.
Nov 26, 2009 | Intel Motherboard
Sata hdd not detected
Jun 10, 2009 | Biostar K8T80-A7 Motherboard
Only detact my sata rom when canect my sata hard disk dasant detact both I just bought a 160GB Maxtor SATA Harddisk (STM3160813AS). When I tried to installed it to the motherboard, it didn't detect the...
I the HDD is still brand new, then it has to be formatted by the PC, install the HDD do the following...
1. Right Click My Computer, click on Manage
2. Go to Disk Manager on the left
3. Your disk should be listed there, right click on it on the right hand side of the screen, create partition, then you need to format the hdd, then you can use the disk, If it doesn't detect the HDD when you want to install windows, then you must, change your SATA setting in the Bios to IDE mode, Try it out and let me know, got some more solutions that you can try if that doesn't work
Cheers
Techmor
May 28, 2009 | Asrock P4VM8 Motherboard
Sata HDD set in primary master in Bios
Try considering these:
1. DOS disk doesn't recognize SATA, that's the truth
2. You're going to have a problem if you install OS in your computer (solution: do not select SATA in HDD type but rather IDE)
3. For your SATA HDD to become primary (boot first) try to select your SATA HDD as devic first to boot..
Jan 04, 2009 | Maxtor Hard Drive
Add sata HDD
Make sure the power cable of SATA hard drive is properly plugged in or not.. It is possible.. Try with SATA 0..
Thank you........
Aug 30, 2008 | EliteGroup (ECS 915PL-A2) Motherboard
Open Questions:
Computers & Internet Logo
70 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
