Bpl tv fXr 21
PICTURE WITH RETRACE LINES,PICTURE DISAPEARE WHEN BRIGHTNESS FULL.SOUND OK,
techman
  • 3130 Answers
SOURCE: Blue Saturation with retrace lines visable
could be but there are a few checks that need to be donr first.. Try to turn down the g2 control just a bit on the flyback transformer. If no effect unsoder the blure drive transistor on the crt board If the blue is still there that means the crt is shorted and you could try to clean the elements with a crt rejuvenator and see if that helps. If the screen goes to red and green after you disconnect the blue drive transistor then you need to check the osd drivers as well as the rgb output drive from the video IC. If the blue gun in the tube shorted or leaky I have in the past and it really works a isolation transformer that plugs in to the crt socket and the other end plugs into the crt. What this does is isolate the the gun of the crt from the filiments and thats where they get shorted or leaky but for how long it will last who knows.
Posted on Mar 26, 2006
  • 2318 Answers
SOURCE: excessive brightness with retrace lines
Here are the values:
RY04 >>>> 68 ohms >>>> 1 Watt
RY04A >>> 47 ohms >>>> 0.5 watt
RY02A >>> 330 Ohms >>> 0.25 Watt.
All resistors should be 5% tolerance.
Posted on Apr 17, 2008
SOURCE: BPL BC-9 SERVICE MODE DEFAUT SETTINGS FOR BPL FZR 21
after some of starting the tv picture become dull n picture disapper but tv doesnt switch off
Posted on Jun 09, 2009
  • 5 Answers
SOURCE: no raster no sound no picture only brightness
just buy a new tv,
Posted on Dec 10, 2009
  • 3 Answers
SOURCE: sound is not coming but picture is ok in philips
sound is not coming but picture is ok in philips 21 RF vardan tv
Posted on Jan 13, 2010
TV is older and has had a great picture through the years. It has now developed blue vertical lines all the way across the screen every 3/4".
Those are retrace lines from too bright a picture. If you can't get them to go away with the brightness control then a repair is necessary
Jun 22, 2015 | Sony KDS-R60XBR1 60" Projection HDTV
Sound is not comming out of my bpl tv ftr21
Can anyone help... I have BPL cv 21 model sp 2B. I have problem. By mistake my repairer have open data manu, and try to slow audio, by doing these he dont know which button he press.. now audio has gone, and auto setting is also not working
Jul 11, 2012 | Televison & Video
Daewoo dtq-206sc have retrace lines
if retrace lines at top of picture the issue is in the vertical circuit--usually a bad filter cap and or the output chip (most of the caps that cause that are 220 uf or 330 uf and connected directly to one pin on the chip.
If retrace lines are across entire screen---likely the master screen control on the Flyback is set too high--causes excessive brightness and the retrace lines.
May 22, 2012 | Daewoo DTQ-20U6SC 20" TV
At first it was lots of horizontal lines over the screen, and later TV screen went completely black. The sound still is perfect. Perhaps I just need to replace the fuse? I love this TV! Thanks...
Hello
You have stated that your TV has a lot of horizontal lines before it went off picture. We say that lines as retrace lines. So many of them will there on the entire screen, at about one inch or so apart, horizontaly scattered along with picuture. At that time, you may be unable to down the brightness control also. Even though you have reduced the brightness control to zero position, there will be some brightness level on the screen. You should have to repair that fault at the begining. There is a voltage going to the picture tube base, known as screen voltage. That voltage determine the emission of the picture tube, and we call it a bias voltage. When it goes higher than normal, this trouble ie retrace lines will occur. In long run it may spoil the picture tube itself. I don't know what the case of yours.
Anyway it is best for you to consult an experience technician in this case. Ok.
Nov 05, 2010 | Sony KV-35V35 TV
IM A TV TECH. I HAVE A SONY LCD KP-60XBR800 I HAVE NO RASTER. POWER OK, MENU OK BUT NO RASTER ON TUNER, TUNER VOLTS OK,CAN YOU HELP ME PLEASE. THANKS my email sergioaguirre0182@hotmail.com
check the high voltage with the screen control turned up high where there is no raster. suspect problem within the video circuit where there is no high voltage or defective picture tube.some time when the screen is black and the screen control advanced,you can see if the tv has video or vertical or horizontal problems on the screen.service the high voltage circuit if there is no raster or high voltage is seen.no raster can be caused by the no heater or filament in the CRT.---- a defective picture tube can cause many problems, such as, poor brightness ,missing colors,intermittent picture,poor focus,a single-colored raster,arching in the gun assembly,retrace lines in the picture,negative picture,chassis shutdown,noheater or filament lit and no raster to name a few.an open filament or heater can cause no picture or no raster symptom.a defective CRT can have an extremely bright screen.loose particles of the cathode element can lodge between the grids and cause an intermittent black and white picture. simply tap the ends of the CRT gun assembly and notice if the picture begins to flash off and on.---- with a leaky picture tube after turn on the raster dims and get extremely bright.a dim picture with no green in the raster can result from a bad green assembly. a heater-to-cathode short can cause a raster to change colour or a result in no raster at all.replace the picture tube if there is severe arching in the neck of CRT. excessive brightness with retrace lines and a vertical collapse to a thin line can be caused by a bad coil on the neck board of the picture tube.rejuvenate the picture tube when there is very bright green screen. check for the resistance change on the resistors of the CRT neck board for an excessively bright picture with retrace lines.excessive dust inside the CRT spark gaps within the picture tube socket can cause the very bright raster and the chassis shutdown.a defective video amp,luminance buffer,or reference transistor can cause a bright picture with retrace lines. -------- for getting any required parts to replace you can get it from www.radioshack.com or from www.partstore.com or from www.shopjimmy.com --------- thanks.please do rate the solution.thank you for using fixya.keep updated.
Sep 06, 2009 | Televison & Video
Apr 17, 2009 | Televison & Video
Screen went full bright one day.
Hello, please check the 10uf/200V capacitor around flyback transformer. Best regards, Arpi
Jul 17, 2007 | JVC AV-27230 27" TV
Blue tint and lines on screen.
Those lines sound like "retrace lines" and several things can cause them. The most common are shorts inside the picture tube and shorted semiconductors in the video driver circuits. They can also be seen if the blue screen voltage is too high or if someone has tampered with the screen voltage control.
Jan 20, 2007 | Philips 28PW9536 28" TV
Circuit board was damaged in electrical storm. Replaced with new board. Now, screen comes on full raster, but with retrace lines. Picture is very faded and barely visible behind lines. Sound is OK and...
I am unable to find in your statement about which brand or type of motherboard is used. One thing i come to know your using service mode kit. knowing in your statement your are a technical person. My simple idea is first you set the TV in standby mode using remote. Then in FBT reduce the screen control minimum position, the release standby. Now the tv is oscillated, now slightly increase screen control till get maximum video and zero retrace line set in position. Even no improvement give me clear picture of brand and microprocessor ic etc. there is a chances to solve by having the above details.
Aug 27, 2006 | Sanyo DS31520 31" TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
