Printer samsung CJX1050W error code 3533 - Office Equipment & Supplies
My kodak printer esp 3.2 is giving me an error code 3533 paper jam but there is no paper jammed and when i put new paper in it, it still wont print and keeps giving me the same error code 3533
Turn off the printer and unplug it. Open the top access panel. Inside on the left you will see three round, white gears. Rotate the gear closest to the front back and forth with your finger. If any scraps of paper appear near the rollers, remove them. Close the top access panel. Plug in and start the printer. This worked for a Kodak ESP 3.2.
Sep 12, 2013 | Kodak ESP C310 AllInOne InkJet Printer
Paper jam code 3533
In removing the jam you have pulled aswitch in side loose . Usually a plastic black switch that will trigger this . It is inside and will need to be reset inplace.
Aug 27, 2013 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer error 3533 CJX-1050W
too much paper being put into slot. paper it static so fan it beofre putting in
Feb 11, 2013 | Office Equipment & Supplies
Paper jam error
remove the tonner and check may be a piece of paper be hidden in the machine
Oct 17, 2012 | Kodak Office Hero 6.1
Koday esp c310 error 3533
I have code 3533 code but paper is not jam
Sep 13, 2012 | Kodak ESP 5 Printer
Get a paper jam error code 3533 but nothing in the copier.
I hit on mine several times and slammed it on the table a few more times and it cleared the jam. Seriously.
Apr 04, 2012 | Kodak ESP C310 AllInOne InkJet Printer
Paper jam code 3533? how do I get paper out?
Reset printer:
  1. Remove all paper from the paper input tray.
  2. Make sure the paper output tray is open and free of any paper.
  3. Turn off your printer.
  4. Wait 30 seconds.
  5. Turn on your printer
I hope this will will helpful.
Mar 21, 2011 | Office Equipment & Supplies
My kodak esp5210 printer is showing paper jam remove rear access cover. clear all papper. attach cover. press ok to continue. (code 3533). ive followed the instructions but nothing changes. there never...
I've got exactly the same situation/circumstances and error code, the thing different is that my code changes between 3533 and 3528? sorry I;m no help right now but I'll be back if I solve it. Martin. (Banksy100@hotmail.com)
Feb 11, 2011 | Office Equipment & Supplies
Kodak esp 5210 code error 3533 paper jam no paper in it
Leave the rear cover off, then spam the OK button if the error message remains on. I did that maybe 10 times in rapid succession, then hear a very distinctive CLICK in the back of the printer. I replaced the cover, the hit OK, the printer cycled through startup, and now it's operating normally.
Jan 17, 2011 | Kodak ESP 5 Printer
109 people viewed this question
jasbo
jasbo
