Question about Maximum Thetford Porta Potti 365 Portable Toilet
How do you remove hand pump on porta potti 365
Manual for 1992 Fiamma porta potti
Sorry, don't mean to be pedantic but Fiamma is just a potti not a Thetford Porta Potti. (TM)
I only have experience with Thetford.
Nov 07, 2011 | Thetford Porta Potti
I just bought a used Sportsmobile built in 2002. The Porta Potti was never used butI need a users manual to figure out how to use and maintain it. I can't find a model or serial number. It just says...
According to the Sportsmobile custom website, the porta potti you have is called a Thetford Electric flush porta potti. There is only one electric flush made by Thetford, so a model number is not necessary to locate instructions or a manual that shows maintenance and use ect.
Here is a link to the manual, parts list and usage instructions for your Porta Potti. When the page opens, click on the link on the top right hand side that says "manual" to download a PDF version to save to your computer.
I hope this helps? If you are happy with my solution, please rate it on Fixya! Thanks!
http://www.thetford.com/HOME/PARTS/PortableToilets/PortaPottiElectricand585PartsNEW/tabid/656/Default.aspx
May 31, 2011 | Thetford Porta Potti
Flush pump not working
Unless the inlet pipe has dropped off the pump assembly or got a blockage in it then you may need to replace the pump bellows.
Here is a link to a schematics pdf with all relevant part numbers. These parts are readily available from most camping and caravan equipment suppliers. http://www.leisureshopdirect.com/camping/tents/porta_potti_toilets/Thetford_Porta_Potti_335__345__365_and_spare_parts.aspx?pdf=3880
Feb 22, 2011 | Maximum Thetford Porta Potti 365 Portable...
How to get to the pump in a porta potti 32
Have resolved the issue. Many thanks
Oct 17, 2009 | Thetford Porta Potti
Repairs to porta potti
Go to thetford.com and download user instructions.
Aug 19, 2009 | Thetford Porta Potti
Instruction Manual for Porta Potti
Hey,
Here is the link. You can find the pdf on the right hand side of the webpage.
http://safemanuals.com/user-guide-instructions-owner-manual/THETFORD/PORTA%20POTTI-_E
Hope this helps
Thanks
Apr 18, 2009 | Thetford Porta Potti
Need instructions on how to empty Porta Potti 165
Your lucky day I found the answer to your problem. I also need some info and checked out the net.
Just go to www.thetford.com
You should be able to find a download for your potty as I did for mine!
Hope this helps!
Mar 30, 2009 | Thetford Porta Potti
Maximum Thetford Porta Potti 365 Portable Toilet Logo
37 people viewed this question
Top Maximum Home Experts
Donni Steen
Tom Chichester
Are you a Maximum Home Expert? Answer questions, earn points and help others
