Question about Iomega (33215) 250 GB Hard Drive
Iomega31679300 how am I meant to connect it? - Iomega (33215) 250 GB Hard Drive
How do I make the sound work
As you see in this picture, and AV cable will have these type of pins at both ends. Just see:
Like this. By which; Yellow colored one is meant to be connected to Video In to the TV, and the other end of it to the Video out of the device you do as source; like DVD,VCR LD player etc.
Similarly, the other two colored pins [2 of it] are meant to be connected to the respective colored sockets; both at TV & the source device. These two wires are audio connectors, Left & Right channel. It's quiet simple to connect; and no expertise is needed. Have keen look. That's all.
Gopakumar Gopalan Google
Sep 16, 2014 | Olevia LT27HVX 27 in. LCD Television
I have JVC Compact VHS Camcorder Model No GR-SXM250U what am i doing send data in Computer.i have no softwere CD where can i get softwere CD ? What can i do ?
These analog cameras were not meant to be connected to a PC. There were meant for connection to TV or VCR. If you trying to editing analog footage on a computer, i would recommend using a capture box like PINNACLE DAZZLE.
May 21, 2014 | Video Cameras
LEVITON 7090-BR LAMPHOLDER 3 TERMINALS
I need to ask you for a bit more information. Ordinarily a socket for a 3-way lamp has two external connections, one of which goes to power (black is the standard color) and one which connects to the neutral wire (white is the standard color). The other wire commonly encountered in house wiring is green, which is a ground connection. Lamps normally do not use a ground. The Levitron web page does not flag this socket to be anything out of the ordinary, but neither do they show the connections.
So please provide any additional information that you can on this socket. Is it meant to hold a single, 3-way incandescent bulb, or is it for a florescent bulb? Is it meant for a special purpose?
Apr 13, 2014 | Leviton Electrical Supplies
Which telephone port do i put the line in
These are typically marked with a small Phone Icon - meant to connect the telephone handset, or LINE meant for the wire to the wall. look carefully its written on the jacks, however be careful, some printers also have a LAN port that is similar but larger than a phone cord plug , which is made to connect to your homes network. If this helps please click on the thumbs up for response. Thanks
Aug 26, 2010 | Canon PIXMA® MP530 All-In-One Printer
No ethernet connection on my computer thats hooked up directly to the 2wire router. how do i acquire ethernet connection?
My guess is that the 2wire router has a DTE plug and a DCE plug. The DTE plug is meant to plug in to your DSL modem, while the other plugs are meant to plug into computers.
If you move the plug, it might work, assuming you have an upstream and downstream connection on the router.
Failing that:
Make sure the cable is an ethernet cable and not a phone cable,
Make sure the wires are run straight through. If it is a crossover cable, it might be meant to connect a DTE to a DTE without a hub, and it won't connect a computer to a router port.
Try a different cable.
Try a different computer (borrow one, etc.)
Jan 18, 2010 | 2wire 2700HG-B Router (2700HGB)
Nokia 2600 E symbol
The E symbol is meant EDGE internet connection, you're in the EDGE network coverage. If not in the box, it does meant the EDGE isn't being use at the time.
Jul 11, 2009 | Nokia 2600
Oops...i meant beeps. I was playing with a
Check all the connection from the motherboard something might be loose ...
Jun 24, 2009 | HP (D7580-60003) Motherboard
My versalink modem
if you meant connecting it to a modem it is possible. but if you meant connecting it to a computer to share internet to other computers, then it won't work
Jun 04, 2008 | Westell Wirespeed VersaLink...
Programing stations
I have included a step by step to store your stations. The cables are meant for a sub and yes your system does support a sony cd changer. To install a changer you have to pull the deck and there is a outlet on the back.
Aug 21, 2007 | Sony CDX-M8800 CD Player
Iomega (33215) 250 GB Hard Drive Logo
19 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
