Question about Bosch Water Heaters
Bosch hydropower 10h won't ignite - Bosch Water Heaters
4 Suggested Answers
  • 10865 Answers
SOURCE: Re: 10H hydropower, pilot has
Hello. Use a small stiff brush and a vacuum cleaner with hose to thoroughly clean the entire mechanical area of the water heater. Then go through the steps to light it once again.
Many times a little dust is the problem with these heaters. If the cleaning does not solve the problem the next step is to change the thermocouple. This is a common item available at any hardware store. Joe
Posted on Oct 14, 2010
heatman101
  • 43501 Answers
SOURCE: bosch 10h dosent want to ignite and heat anymore
The unit is plugged up with mineral buildup from the water going through it... it will need to be cleaned internally....this is done by running an acid solution through it to clean out the mineral buildup...
Then it will work again...
heatman101
Posted on Feb 03, 2011
kfwilso
  • 45 Answers
SOURCE: How do I relight my 10H Hydropower? It went out in
the 10 h does not need to be relit it does not have a perminant pilot when you turn on your tap the water flowsthe hydro ignitor spins igniting the pilot and then the burner.
Posted on Jun 18, 2011
Need help with Bosch hydropower 13h tankless hot water system
when you turn on the hot water tap there is a pressure switch in the line that sends a signal to a gas solenoid to pass the gas and at the same time to the pizo to start the flame
I would have that pressure switched checked as it may be sticking ( internal contamination) or have dirty corroded points
as gas is involved I would suggest a gas technician do the jib
when you turn off the tap, that pressure switch is shut off so the gas is turned off at the solenoid and the pizo is stopped.
May 21, 2015 | Bosch Water Heaters
Bosch hydropower 13h gas water heater not working
the tank is possibly full of gunk and the thermostat is not sensing the request for hot .flush tank if you can thru the bottom drain a few times if it is bad enough that ou get no water out then only option is to replace with a new unit
Hydrapower 10h -pilot lights but gas wont light only lights when I tap the pilot tube. Then works for a while and reverts to not lighting the gas again
First suspect is air in gas line or dirty combustion parts.
Typical gas water heaters today suggest cleaning burner parts yearly, including bleeding air out of gas line.
Use a burner brush to clean tubes:
http://www.rvparts.com/product-85-91872
Other suspect could be faulty wiring or bad gas valve.
Jun 15, 2011 | Bosch Water Heaters
How do I relight my 10H Hydropower? It went out in the rains last night. Casing instructions have faded and on/off switch referred to in an online manaul doesn't exist.
May 30, 2011 | Water Heaters
I have a instantaneous water system 10H Hydropower ...did not get a manual when installed....I need to have hotter water as it's winter and the water is like warm...not sure what to adjust...opened...
take the cover off the 10 h unit light up the burner by turning on the tap turn the water flow tap on the front of unit (white knob) clock wise slowly feel hot water pipe coming out off unit when temp increases put cover back on check temp at sink if too hot turn knob anti clock wise
May 23, 2011 | Bosch Water Heaters
Bosch 10h dosent want to ignite and heat anymore low pressure light flashes
heatman101
Jan 31, 2011 | Bosch Water Heaters
I have a 16h Bosh hydropower hot water heater . The unit suddenly has no spark .I have taken off the little generater cap and thouroughly cleaned it and the internal turbine . With no improvement . All...
sounds like the generator has packed up. check water flow and clean any filters on the water line. you will need a service agent to check milli volts on generator and power pack
Dec 15, 2010 | Bosch 1600H-LP Liquid Propane AquaStar...
I have a 10H hydro power. there is not enough pressure to start the turbo with the gravety feed. do you have any advise other than apresure pump.
if you can disconnect the main line going to the heater easily try attaching a smaller line that might provide enough pressure. this is just an idea if its easy to do try it. how much pressure do you need?? to run the heater.
Dec 13, 2010 | Bosch & Tankless LP Hot Water Heater
Low Water Pressure Gas System but High Pressure when Solar Water
if you have a gate valve on the unit from the hot water tank it could be as simple as the valve on the gas system being clogged going to that bathroom,, from how it is described it sounds like that would be the problem check to make sure all valve are not stuck in the on position ans change the valve if it is frozen in place
May 22, 2009 | Water Heaters
I have a 2nd hand Bosch HydroPower LPG hot water system and am trying to find a manual. do you have one or is it pretty straighforwward in terms of installation? Mike
I have just dug my manual out (16H) because mine is faulty. email me and I will photocopy it at work this week and email it back to you.
Installation should be pretty straightforward and the manual's not that in depth. There are however some sections on adjusting the gas and the like that you might want to read over.
mchankey at gmail.com
regards
Mark
Dec 04, 2008 | Bosch & Tankless LP Hot Water Heater
Water Heaters Logo
797 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
