Question about Logitech 961462-0403 Webcam
Dck-tgcam-30(b) install - Logitech 961462-0403 Webcam
Problems known about dck dog treats?
Depends on the dog...does he normally have a sensitive stomach if so duck might cause diarreahha...but happy hips makes a great one it's dried my dogs love them...and it has glucosamine...in it...so there happy and healthy...try that first....the other brands tend always give a sensitive stomach dog the runs...and the poor guy won't feel good...which means you will feel worse...trust me....I'm a true blue animal lover...
Mar 02, 2013 | Dogs
Once i have my dck code to unlock my phone what do i do?
You can get the Unlock code at here http://www.unlocking4u.com/supported-phones/rs6wp7/
and Unlock it......check code for Your Network lock,Brand and model in the List...
Feb 28, 2011 | Cell Phones
Replaced water pump and now i need to know how to reset timing
I hop you are replacing the belt and tensioner/ idler pulleys. the crank pulley has a notch approx 12'oclock. the cams will be marked rear cam "I" and front cam "E" .. put both letters at 12 o clock. there should be a notch at the top of the cover for the cams at 12 o clock. thats all there is to it. to tension the belt, after you have it all timed up. put some tension on it, tighten tensioner bolt, turn the engine 2 revolutions, then double check your marks, push down with you thumb between the cam sprokets with 20 lbs of force, the belt should delfect about 10MM if its too loose, loosen the tensione rbolt an dturn it tighter a little more an dck tension again. If you get it too tight it will whine and wear the cam journals, too loose and timing will not be correct.
Sep 18, 2009 | 2001 Kia Sephia
I HAVE A PROBLEM TO INSTALL DRIVE FOR DIGITAL OLYPUS DS-30
you will need drive letter assignment for your device... located in control panel, disk management
Mar 01, 2009 | Olympus DS-30 Digital Voice Recorder
Trying to hook up ipod thru receiver to Sony TV???
Check the ipod.It will have a setting called tv on, or output to tv.
Oct 05, 2008 | Yamaha RX-V3800 Receiver
3" tft PLD3MU
on the back of your dck there should be a grey wire that needs to be grounded to something then it should work fine
Jul 21, 2008 | Pyle PLDVIN7 Car DVD Player
I recently received a really nice R600 Kenwood.
Hi Doug,
To my knowledge, the Kenwood R600 straight from the box runs only on AC power hence no DC jacks.
However, there is a DCK-1 accessory which is a DC cord kit for this receiver.
Alternately, the secondary output of the transformer is 14VAC which is feed to the bridge diode of the power supply on the PLL unit/board. With that in mind, it would then be OK to hardwire 13.8VDC right after the bridge diode and parallel to the big filter capacitor. It may be a good idea to put an inline reverse protection diode and a fuse. Of course any DC type of jack/plug combination/arrangement may also be used.
Additionally, you might be interested in a service manual for the Kenwood R600 which is available here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 04, 2008 | Kenwood...
Logitech 961462-0403 Webcam Logo
108 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
