My Sharp Copier AR 5618 is showing error F2 -64, i have bought a new toner cartridge and installed it yet its still showing F2 -64, please a need a code to clear this problem.
  • 148 Answers
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Posted on May 26, 2008
  • 92 Answers
SOURCE: crum data read trouble in sharp ar 207
The CRUM chip is what tells the copier that the correct toner is installed. It is specific to the toner cartridge. If it is a new cartridge then it should have a new CRUM chip and there should be no problem. If it is a recharge it's possible that the chip was not changed or the wrong one was used.
Posted on Oct 16, 2008
007tech
  • 95 Answers
SOURCE: sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Posted on Apr 23, 2009
M2Tech1
  • 313 Answers
SOURCE: ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Posted on Jun 12, 2009
xptareq2000
  • 1447 Answers
SOURCE: Sharp AR-M208N copier with error code U2-40. What
reset u2
press c -interrupt-#-interrupt
press 16
press start
machine off
again machine on
remove this signal.
Posted on Jan 20, 2010
I bought new toner since then my ar-5618 sharp photocopier is showing F2 and when i press start is showing 74. please what do i do to clear it?
The problem is with the toner....there is two way solution change toner or more economic way change the chip of your existing toner....the sharp copier tend to burn the toner chip.
Oct 31, 2014 | Office Equipment & Supplies
If you don't have a user manual, you can download one in PDF form for your copier at the Sharp website. That may have a legend to explain what the error code means, and how to fix it.
Nov 11, 2013 | Office Equipment & Supplies
AR 5516S SHARP COPIER IS SHOWING F2 4O FAULT CODE DURRING INSTALATION. WHAT COULD BE THE CAUSE. PLEASE.
During installation , use sharp ar205 developer and sharp ar021 toner cartridge. This shows you did not use developer or used the wrong ones, good luck.
Mar 12, 2010 | Sharp AR-5320 Black and White Copier
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
Replacing of new Cartridge problem
good day sir
I am Josco and my Email:oyas20102005@yahoo.com.
I have a lot of Sharp Copier but there is one that is giving me comcern coming out with a code (showing H & 4) and i can not work with the copier Sharp Digital AR-5316. please what do i do and it is the newest copiers among all, please i will be very glad to recieve a code so as t clear the interupting showing H & 4 on the copier.
Thanks
Josco from Nigeria.
Nov 03, 2008 | Sharp AR-5316 Advanced Digital Imager...
May 23, 2008 | Sharp AR-M237 Copier
20 people viewed this question
k24674
jasbo
jasbo
