Question about Altec Lansing Audio Players & Recorders
Power ic part number of altec lansing acs21w - Altec Lansing Audio Players & Recorders
  • 277 Answers
SOURCE: Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Posted on Mar 21, 2006
SOURCE: Finding replacement Power Supply for Altec Lansing
I did the same! Thanks for suggesting a call to Customer Support (800)258+3288. The guy didn't seem overly pleased to help, but he did promise to send me a new power supply. Also, he said that they don't make the iM7 anymore, but I had already found out that the iM9 uses the same power supply. I, too, will wait and see.
Posted on Jul 07, 2008
  • 4 Answers
SOURCE: What's the volt & amps of Altec Lansing AVS300 2.1 speaker system
Your adapter is Part No. AVX300-A6859, Model No. 9701-00748-IUND.
Or You could get a universal that is rated for output of 18volt DC, 650ma, Center Positive.
I have used a 15volt DC, 900 ma with no problem, but I never run the volume high.
Good Luck
Posted on Dec 04, 2008
SOURCE: Altec Lansing In Motion Power Supply
Look on your power supply for the output voltage and amperage. It should say something like "Output: 9V DC 500mA". With this information you only need to get one with the same plug.
When you do please post the answer because I have the MLI699 speakers and don't know what power supply is needed.
Posted on Jan 29, 2009
edwinmeyer
  • 57 Answers
SOURCE: I have Altec Lansing AVS 300 multimedia speakers with no power
Unfortunately the subwoofer supplies the power to the amp on the speakers, Once again I have the solution,
These speakers are factory molded so that the only way to open them is to break the factory seal
this can be done by sharply rapping the seam at the bottom of the speaker with a heavy screwdriver handle or something similar.
Now you need to supply power to the amp...If you do not have the subwoofer you will need a 4.5volt power supply, after removing the board from the casing find the red white and black wires connecting
the orange plug wire to it, Personally I removed the entire cord from the unit, shough you can splice in at this point if you desire.
Connect the white lead to your posative on your power supply by either splicing or soldering, connect the ground to the heat sink using the screw that is already there holding the chip to the sink. reassemble the speaker.....super glue... and you are now in business.
Ed Meyer
Owner AACS
www.alwaysaffordablesolutions.com
Posted on May 22, 2009
How can my laptop charger fit to computer speaker?
Please do not modify your laptop charger to power your speakers. The laptop charger probably has too high a voltage and amperage output. (USB chargers don't provide a large enough output.) The Altec Lansing ACS40 speakers need a 15V 900 mA power transformer; the coaxial power connector has the positive voltage on the center pin. The model number on the transformer is 4815090R3CT . This is available through Amazon.com and other vendors. One vendor is http://www.emtcompany.com/altec-lansing-4815090r3cac-power-supply-charger-adapter/1010666.html .
I hope this helps.
Jun 03, 2014 | Altec Lansing Audio Players & Recorders
Hi i am looking for part nmber of ic for altec lansing acs 45,amplifier stage.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
May 12, 2014 | Audio Players & Recorders
MODEL A425 main ic number
This chip is NOT going to be available commercially. The programming will be proprietary and owned by Altec.
Mar 19, 2014 | Altec Lansing ADA425 3-piece 30-watt...
What is the dc voltage for Altec Lansing ACS 66i
friend chk your adapters back it must be written on it....
Jan 20, 2012 | Altec Lansing Audio Players & Recorders
My Altec Lansing VS4121 is having a sound as if it is grounded or something. First I thought it was just a wire connecting to my pc but it isn't. I tried to unplugged it to my pc but still producing the...
Hello Adrenalize, hi, you may be right, but also check other ICs as well, the humming sound can be caused by the amplifier or its preamp section, this is where the 1036 (this is a dc operated tone control) is located. But before replacing the 1036, try first replacing the POWER AMP IC. (my experiences with those humming sounds usually are caused by IC amplifiers and op-amp ICs.)
Dec 05, 2010 | Altec Lansing VS4121 Speaker
Altec lansing AVS 500 IC
The amps are 8-pin CHN 4558CN [K1D142] and 8-pin PHIL TDA8199 [LD8136] The Voltage Regulator is a 14-pin LM324N There is a 3-pin LM7812CN 12-volt regulator... They are in the sub-woofer housing which is held in place by tape so it can be pried off if done with care. Hope this helps. If you have all the cables and wires in place I would appreciate knowing the connection sequences (someone cut all the wiring to the set I have.)
Jan 22, 2009 | Altec Lansing 621 Computer Speakers
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
Hi Yeo...
Amazon offers pretty much power supply products, click on this link Finally charging for our multi device world and choose your model.
I hope this was helpful.
enjoy
Feb 20, 2008 | Altec Lansing Multimedia Computer Speakers
37 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
