Question about Huawei Premia 4G
Huawei Problem when plugged in battery light flashes few min. then nothing. after few min later, battery light flashes 3 times but doesn't turn on...no power
    Scholar:
  • 86 Answers
Try performing a factory reset through the service menu, If it's still under warranty then you're in luck. If its out of warranty then you're like me trying to also find someplace to JTAG Huawei devices anywhere in North America.
Posted on Dec 04, 2014
  • 2,973 Answers
It seems that your firmware has got corrupted (if the battery is fine). Check the battery first. If found OK then re-install the firmware. If the battery is gone then replace the battery. I feel the battery may be fine.
Posted on Oct 22, 2013
Sony bravia vpl-aw10 lamp come on runs for 2-3 mins then switches of and lam p cover light flashes 3 time repetedly
Here is a link to the manual. It states you need to replace the lamp because it has reached it end of life an over heating.
https://docs.sony.com/release/VPLAW10.pdf
Jan 28, 2015 | Sony Bravia® VPL-AW10 Projector
My huawei phone u8185 failed to reboot after writting on the screen force close ,of which i put power off and it diidnt turn on
Have you tried removing the battery, hold power button in for a few mins then put battery back in see if it will boot up..It discharges this may help.
Have you tried to do a hard reset?
Hold down the power button and volume up key at the same time for a few mins and you should see the android menu come up to where you can select factory reset with volume button. Hopefully it will bring it up.
Mar 04, 2014 | Android Cell Phones
Something is draining my battery 134,000 M
IT costs nothing to have a load test done on the battery to check for a dead cell which your problems point to. While the engine is running the alternator will be handling the power requirement but the battery will not supply the power required to start.
Aug 25, 2013 | 2001 Volkswagen Jetta TDI
1999 Sunfire 2.2L wont start
Try starting it with the shifter in neutral. You might have a bad
Neutral safety switch.
May 14, 2010 | 1999 Pontiac Sunfire
Laptop won't switch on
Your laptop went to sleep mode and could not wake up. Press and hold the power button for about 10-15 seconds. It will turn off and you should have no lights at all unless you have the AC connected.
Turn it on back again and it should be fine.
Check your power options under control panel and see the options for sleep or hibernate and disable it so that it wont happen again.
Hope this helps.
Dec 21, 2009 | Compaq Presario CQ60-220US PC Laptop
Power light flashes 3 times
You can get the CP150, CP120 and Cp114 repair kit at the following link which will usually repair that issue. Its at the bottom of the page under the RCA repair kits. The kit contains the capacitors and detailed instructions how to do the repair. www.tvrepairworld.com
Sep 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Freezing screen
remove the battery for few minute if it still dont work look in the manuel how to reset normally they put it in the back small push it with a pen hope it work cheers
Jan 18, 2008 | Samsung SGH-d807 Cellular Phone
Plugged in, worked, turn on later, did not work
First thing i would do would be to check convergance amp ics
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 01, 2008 | Toshiba 55H70 55" Rear Projection...
Huawei Premia 4G Logo
1,002 people viewed this question
Top Huawei Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Huawei Radio Communication Expert? Answer questions, earn points and help others
