I know that MO drives were introduced in 1985 but are they still in use today or gone like the floppy disk?
When was the first magneto-optical disk drive used?
they were first used commercially in 1985
Jan 23, 2013 | Computers & Internet
My TEAC FD-05PUB is recognized by my computer. However, it will not open a floppy disk. It says the disk needs to be formatted (even thought the disk works fine on other computers with the same operating...
Try a brand new disk put something on it and go from there the disk you may be using may be no good anymore. Try this first before getting another replacement disk I would stop using these floppy and go to a USB Stick for storage purposes since they are going obsolete. Just a suggestion! That would solve your problem using floppies for storage besides they do not hold much information compared to todays storage devices. John
Jan 15, 2011 | Teac FD-05PUB External Floppy Drive
Ep-8k9a mobo disk access problems
Mo bo has nada to do with reading, writing, disks. That is the domain of the floppy drive and/or optical unit. You replace the latter drives.
Aug 07, 2017 | EPoX EP-8K9A Motherboard
Windows Vista shuts down when trying to access floppy drive
floppies are very much vulnerable to viruses. there might be an issue with the computer getting affected. i strongly recommend that you run a antivirus program before proceeding further. good luck!
Oct 14, 2009 | Dell Inspiron 530s Desktop Computer...
Ican't get a self installed floppy disk drive to work with Vista.
Reverse the data ribbon direction in floppy side (data cables pink color side should be plugged opposite to power cables color side)
Sep 25, 2009 | Teac Floppy Drive 235HF Internal Floppy...
Bought this New Dell Internal / External USB Floppy Drive 1.44Mb
Hello there
you will need to check the way the device reads the disk if may have changed if you tried using a ordinary dvd then went a dvd/r some times you need to change the settings back to the way it was when you installed it ok
best regards mike
Aug 05, 2009 | Dell 1.44 MB USB Floppy Drive (1y513)...
It would appear that you may need to do a couple of things in order to restore the drive back to normal. I would disconnect the drive using the icon provided to this effect and doing it after the message says it's safe to disconnect it.
If the message says differently, I would still disconnect it, unles you're in the middle of writing, which you're not.
Upon reconnecting the drive, should the condition persist, I would recycle the laptop and try again. It does not make sense that a disk that you recently read from to burn a CD is no longer readable, unless the mechanism inside the drive had collected debris that caused the data on your floppy to be ruined. That would be an unfortunate disaster.
If rebooting the laptop still fails to read the disks, then try blowing any dust or dirt from inside the drive using one of those small canisters of compressed air that people use to clean their keyboards and other devices and try again.
Should the condition persist, try loading the floppy disks on another system to see whether they've been ruined by your drive.
If they are readable, then the drive would appear to be deffective.
My floppy drive tells me to insert a disk when I try to use it
Sounds like you have a bad drive or the disk is corrupted. Did you try a different floppy disk to see if the drive is functioning?
Mar 21, 2009 | Computers & Internet
Operating System not found
This is indicative of:
1) You have a floppy disk in the floppy drive. Remove the disk.
2) Your hard drive has gone bad and needs to be replaced.
Thanks and please take a moment to rate as fixya.
Jul 06, 2008 | Sony Computers & Internet
Won't read disks
Hey Rorel,
The issue could be either the floppy drive or the disk. If you have another computer with a floppy drive or know someone that does try using the disk on their drive. If the drive cannot read the disk then the disk is bad. If it ok the external floppy drive could be bad. Keep me posted.
Thanks,
Tech101
Jun 23, 2008 | Teac Floppy Drive 235HF Internal Floppy...
Computers & Internet Logo
680 people viewed this question
David Payne
David Payne
