Question about Huawei Premia 4G
Huawei power issues
Battery light flashes 3 times. power doesnt come on. if on charger battery light flashes few min then nothing will happen for several minutes
  • 246 Answers
Reset ur phone
Posted on Nov 04, 2013
Philips htl2100/12 soundbar doesnt respond to remote control after plugging in
My soundbar won't power up. So I pull the battery out of remote, press a few buttons, put the battery back in and all of a sudden the device can be powered up and controlled. Until next time it stops responding. I replaced that original battery with a new one but the problem still persists.
Dec 10, 2013 | Philips SoundBar DVD Home Theater with...
HI I HV A HUWAEI M931 AND IT WAS WORKING PERFECT AND ALL OF SUDDEN IT DOESNT POWER ON AND I JUST GET A FLASHING RED...
Make sure the battery is full charger or remove it and use the power cable only .if the power work the problem is the battery. Press the power button 3 time then hold it until il power off. Turn back on. Open it and make sure the conection from the LCD is right pug it to the main circuit look for standby and weikup key combination on the manual.
Nov 23, 2013 | Huawei Cell Phones
Huawei Problem
It seems that your firmware has got corrupted (if the battery is fine). Check the battery first. If found OK then re-install the firmware. If the battery is gone then replace the battery. I feel the battery may be fine.
Oct 20, 2013 | Huawei Premia 4G
My phone will not charge
You probably tried taking the battery out and using an eraser, clean the terminals of the battery, replace do not power phone on, plug in charger and see what happens.
Aug 03, 2017 | Alcatel Lands Phones
I have received as a gift a Canon FS300 Digital Video Camcorder . The first time I used it, I followed instruction on how to charge the battery with CA-570 Compact Power Adapter which was included. It wok...
Hi!
Almost sure there is nothing wrong with your battery, charger and camcorder.
The battery loose power even when doing nothing, especially when it is a NiMH type.
Please charge the battery for a couple of hours and try again to start the camcorder.
Aug 09, 2011 | Canon VIXIA FS300 Flash Media Camcorder
Hi i have put power supply in anbd powered up my power supp;y shows green light but when i press power on butoon on my e1705 nothing happens no lights flash nothing totally dead
Hi
Please can you try the followinf
1) remove wall charger
2) Remove battery
3) Press and hold power button down for apporx 30 seconds
4) Plug in wall charger
5) Power on laptop
6) If successful plug in battery
Regards
Shauqat
Apr 19, 2010 | Dell Inspiron E1705 Notebook
Motorola S9 headset won't charge batteries
This might work if you aren't using the ORIGINAL charger. I had this problem when my cat chewed through the original Motorola charger. I figured my Blackberry charger would work fine, but it didn't. I then discovered that my Blackberry charger was 700mAH and the broken charger was only 550mAH. When I found another charger with the proper power it charged. I also found that it worked when plugging it into my computer with a standard mini USB. I hope this helps.
Jun 03, 2009 | Motorola Mobility S9 Headphones
Presario v2000 stuck in hibernation, can't power it up
remove battery plug in power...see what happens ...nothing happens press and hold power button until you hear response(shut down)press power as usual to boot.if it doesnt work first time try a few times more remember to keep power button pressed to shut down.
Oct 19, 2008 | Compaq Presario R3000 Notebook
02 xda orbit..
If the light doesnt turn to orange after a few minutes on the charger then the problem hardware related. Try another battery if there is no change then there is fault in the device, and repairs are required.
also you can try
this:
1. Plug it in the Charger without the battery inside.
2. switch on the power.
3. Without removing the charger plug in the battery.
4. Light should turn orange.
5. Wait a moment or two then power it on.
that might get it to work.
May 09, 2008 | O2 Xda IIs Pocket PC
Huawei Premia 4G Logo
128 people viewed this question
Top Huawei Radio Communications Experts
eradiostore
eradiostore
Are you a Huawei Radio Communication Expert? Answer questions, earn points and help others
