Question about ASUS P6T7 WS Supercomputer Core i7 / Intel X58/ DDR3/ Crossfirex & 3-Way SLI/ A&2GL/ Ceb Motherboard
How many core ? - ASUS P6T7 WS Supercomputer Core i7 / Intel X58/ DDR3/ Crossfirex & 3-Way SLI/ A&2GL/ Ceb Motherboard
  • 3 Answers
Do you mean how many cores does the i7 processor in this machine have? If so, please check if you have more info on the model nr if this i7 cpu and I can check for you.
Posted on Oct 20, 2013
Testimonial: "said the others is 12 ?"
Heater core leaking through floor vents.
Bad heater core you will need to replace it. About a 2 hour job, very easy to do:
Remove the HVAC module assembly. Refer to HVAC Module Assembly Replacement.
Remove the HVAC filter cover.
Remove the heater core/evaporator tube seals from the module.
Remove the heater core cover screws (1).
Remove the heater core retaining screws (1).
Remove the heater core retaining straps.
Remove the heater core.
Remove the rubber seals from the inlet/outlet pipes of the heater core.
Installation Procedure
Install rubber seals to the outlet/inlet pipes of the heater core.
Install the heater core to the module.
Install the heater core retaining straps.
Install the heater core retaining screws (1).
Install the heater core cover.
Install the heater core cover screws (1).
Install the heater core/evaporator tube seal from the module.
Install the HVAC filter cover.
Install the HVAC module assembly. Refer to HVAC Module Assembly Replacement.
May 19, 2011 | Cadillac DeVille Cars & Trucks
Heater core replacement
If it is necessary to remove the heater assembly, the cooling system must be drained before removing the heater core.
When a heater core leaks, a new heater core is installed or the old one repaired.
Heater Housing
  • The heater housing is usually under the dash and must be removed to gain access to the heater core.
  • Procedures for replacing the heater core vary with the year, make, and model of car. It threfore necessary to consult the manufacturer's repair manuals for the proper procedure for replacement.
f74-01.gif The heater housing is disassembled to get to the heater core. Heater Core
  • Remove the access panels(s) or the split heater/air conditioning case to gain acess to the heater core.
  • Remove the heater coolant hoses.
  • Remove the cable and/or vacuum control lines (if equipped).
  • Remove the heater core securing brackets and/or clamps.
  • Lift the core from the case. Do not use force. Take care not to damage the fins of the heater core when removing.
  • To reinstall the heater core, reverse the removal steps.
When the heater core leaks and must be repaired or replaced, it is a very difficult and time-consuming job primarily because of the core's location deep within the firewall of the car. For this reason always leak test a replacement heater core before installation.
Jan 06, 2011 | 1996 Ford Explorer
Heater Housing
Dec 31, 2010 | 1991 Toyota Camry
Replace heater core
For heater core replacing procedure. I suggest you to go through this related help links.Its all complete step by step procedure: ----How to replace heater core for All car models?
Click the link below: ---
http://technoanswers.blogspot.com/2011/11/how-to-replace-heater-core-for-all-car.html
How to Flush Heater Core?
http://schematicsdiagram.blogspot.com/2011/12/how-to-flush-heater-core.html
How to Remove Heater Core ?
http://howtobyme.blogspot.com/2011/12/how-to-remove-heater-core-on-2008-honda.html
Heater Core Replacement?
http://howtobyme.blogspot.com/2011/12/honda-heater-core-replacement.html
To replace heater core?http://technoanswers.blogspot.in/2012/02/how-to-replace-heater-core-on.html------
How to replace heater core?http://technoanswers.blogspot.in/2012/02/how-to-replace-heater-core-on_10.html
----------This will help.Thanks.
Dec 26, 2010 | 2004 Ford Freestar
Heater Housing
Dec 12, 2010 | 1999 Ford Expedition
Heater Housing
Dec 10, 2010 | 1999 Chevrolet Blazer
Leaking heater core~how to find the core?
Inspect/Replace If it is necessary to remove the heater assembly, the cooling system must be drained before removing the heater core.
Heater Housing
Dec 08, 2010 | 1995 Ford Windstar
Heater Housing
Dec 02, 2010 | 2004 Volvo S40
Heater Housing
Nov 27, 2010 | 1994 GMC Sierra
What is the main difference between dual core and core 2 duo? processor
1. Dual core is the generic name given to processors that have 2 cores on the same chip 2. Core 2 Duo is the second line of dual core processors from Intel 3. Other dual core processors aside from Core 2 Duo are the Core Duo from Intel and the X2 series from AMD 4. All Core 2 Duo processors are dual core but not all dual core processors are Core 2 Duo
For more info visit the link below
http://www.differencebetween.net/object/difference-between-dual-core-and-core-2-duo/
Nov 22, 2010 | Computers & Internet
ASUS P6T7 WS Supercomputer Core i7 / Intel X58/ DDR3/ Crossfirex & 3-Way SLI/ A&2GL/ Ceb Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
