Did it come with Win8 installed already? Was it ever working before? Or did you install Win8 on this machine and now it won't boot up?
SOURCE: windows does not load after gateway logo
This sounds like you have no operating system on your laptop. I bet someway, just as I did before, you have lost your operating system, and it needs to be reinstalled on your computer.
SOURCE: qosmio g30 , problem with boot up screen
try the following
update your video graphic drivers,
try with another ram,
if still you have problem try to repair or reinstall the os
SOURCE: Gateway MA7 black screen, no bios
Take out the hard drive, take out the dvd drive. If you still don't get any video, try another stick of RAM and if that still doesn't work, then the motherboard is definitely bad at that point.
SOURCE: Will pass bios but then will not load windows
step 1. open up the case and locate your hard drive
step 2. carefully remove the cables and power to the hard drive and remove it
step 3. goto your local office depot, staples, walmart or radio shack and buy a nice new hard drive somewhere around 250 gigs should be plenty for you,
step 4. now that yopu have a nice new hard drive put it in the spot where your old hard drive was in the conputer and plug both cables back into the new hard drive, after this is done put your case back on and start the computer up with your windows cd in the cd rom drive and reinstall windows. :) hope this helps
SOURCE: Need to Restore My Acer Aspire 5315
There are two basic ways to restore Acer 5315 PC Notebook to the
original setting. The first method you can try to pressing the key Alt +
F10 for 5 times while startup
process appears on the Acer screen. Usually this way will restore the
original setting automatically.
And the next method you may need to use system restore at the first
time you've got your Acer 5315 laptop. Here are steps to follow:
Log on as the Administrator => Start => All Programs => Accessories => System Tools =>
and click the System Restore. System restore will run and here you
should see the Welcome System Restore page appear. Click Restore my computer button to an early time if
it's not already
selected. Click next to continue the steps.
There is on your Acer 5315 laptop screen a Restore Point page appear,
you can select it and then click the most recent system checkpoint it,
click a restore point list. After you click the Next button, System
Restore message may appear that lists configuration changes that
System Restore will create. Click OK.
For the last step click next button on the Confirm Restore Point
Selection page. Now the 'System Restore' will restore the previous Windows XP configuration on your Acer
5315 OS system. Just finish it by restarts your Acer laptop.
Now log on again to your Acer 5315 PC Notebook as Administrator and
watch the System Restore Restoration
Complete page appears. Click OK.
