Indesit wg820 power spin
2 Suggested Answers
  • 1294 Answers
SOURCE: Indesit WG820 no power in spin
For your model I hope you will find the filter, seen similar models. Disconnect the machine from the mains outlet. Below the door, there's a plastic cover full machine width. Just remove it and on the right you'll see the filter. Unscrew the filter counter clockwise, clean it, check the pump blades and inlet for some foreign objects and screw filter back on.
Posted on Jun 01, 2008
Indesit washing machine pumnp burnt out, replaced it but it still won't pump or spin. Does it need a new programmer or can the programmer be fixed?
You're absolutely right. If you look at the wiring diagram on the machine it is clear that the drain pump is powered by triac on PCB (part code C00270972).
I think it is definitely safer and probably cheaper to replace than to repair the PCB.
It is always a good practice to visually inspect PCBs that there are no visible defects such burnt out elements, etc. before replacing. Sometimes the reason for burnout PCB may be on a completely different side.
25580311-2cx31aa5jn1eijqkorrs11s2-4-2.jpg Dado
Mar 16, 2015 | Indesit Washing Machines
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
FINISHED SPIN CYCLE THEN POWER WENT OFF
If within warranty, contact you local. This fault can be electrical. Electronic board, motor, loose cable against metal can cause blown fuses.
Jul 25, 2009 | Indesit WA 115 Front Load Washer
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Indesit washer model number wg 1432 wont spin
Make sure the washer has fully drained, if it has filter, remove and clean, check your user instructions if you are not sure.
If you stillcan't get it to spin after these checks, come back to me.
PLz rate this solyution.
Thanks.
Jan 02, 2009 | Indesit W 123 Front Load Washer
Washing machine wont spin
Your machine may not be receiving adequate voltage to start. Make sure your machine is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your machine. Also, refrain from using an extension cord to plug your machine in.
Dec 03, 2008 | Indesit W 123 Front Load Washer
Jun 01, 2008 | Washing Machines
Where is the agitator in a Indesit WG1385
Open machine's rear panel and remove belt. Check if motor spins (when it should, as per cycle stage). If motor is spining - Move tub manually and check for smooth spin In case it doesn't spin smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, you should remove it. In case motor doesn't spin- Check with multi-meter if it get power. If it get power - The problem is with the motor. Good luck !!
Jun 07, 2006 | Indesit W 123 Front Load Washer
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
