Question about Asrock ConRoe1333-D667 Motherboard
Always cmos setting wrong but i change new battery how can i fix it
2 Suggested Answers
  • 158 Answers
SOURCE: CMOS Battery do no work
Just change your CMOS battery with a new one and after that goto the bios settings and update the time and dare.
After that just save the settings and then check that the warning message is coming or not.
If its coming then it means you need to change the CMOS jumper settings.
Posted on Mar 09, 2009
We have some problem with Clock system.
change the battery for cmos on board if that dose not work then you need a new board.
Nov 25, 2013 | SuperMicro X5DPL-IGM Motherboard
ASUS P5GZ-MX: Cmos Settings Wrong - Tryed New Cmos battery and setting time a date howto fix ?
It may just be that the new battery needs to be charged. I would leave it switched on for 24 hours to check. If this doesn't fix the problem, it could also be a failing BIOS chip or the charging circuit for the CMOS battery has failed. If the BIOS chip is not socketed or the cmos charging circuit has failed, you will need to replace the motherboard or find an electronics engineer to replace the failed components, this will probably be more expensive that a new board.
Jun 13, 2012 | ASUS P5GZ-MX Motherboard
Why do date and time keep setting to default?
Are you sure you replaced the CMOS battery with a fresh one? Did you install it backwards (the plus side should be UP). I've only seen a bad CMOS battery cause that problem. I would try one you know is new and check the installation.
Good luck.
Dec 27, 2011 | EliteGroup ECS H61H2M2 Intel H61 Sandy...
Laptop wont start
This issue is often caused by either an incorrect setting in CMOS Setup or a bad boot device, such as a bad hard disk drive.
  1. Verify your boot options are properly set in CMOS setup. I recommend having the CD or disc drive as your first boot device and then hard drive as the second boot device.
  2. If your CMOS Setup has an option to boot from the LAN disable this option.
  3. If you have changed any CMOS settings, make sure to save and reboot the computer.
If this does not resolve the issue, try resetting the CMOS values to the default settings, save and exit.
If this fixes the problem but it reoccurs again later you main need a new cmos battery. Or keep your battery always slightly charged.
Nov 16, 2011 | Toshiba Computers & Internet
The time on my computer is always wrong. I change it and the minute my screesaver comes on it is wrong again. I think its the cmos battery. I need to know where it is in my laptop....sony pcg-grz660 and...
When you first turn on the machine do you get a message about it reverting to default bios settings? If not I doubt its the CMOS it could be any sort of malware messing with your time settings, especially as you say it happens when the screensaver comes on.
When a CMOS battery starts to go you will notice a change in the bios long before the time goes.
Oct 29, 2010 | Sony VAIO GRZ660 Notebook
Mar 09, 2009 | Asrock 845GV (P4I45GV) Motherboard
Always f2
If I understand correctly your saying when you exit the cmos, id doesn't save your changes. Make sure when you exit you select the option to save and exit. If that doesn't work, your cmos battery is dead. Look in the mobo manual to find out what replacement battery you need.
Harris
May 01, 2008 | Asrock P4I45GV R5 Motherboard
Asrock ConRoe1333-D667 Motherboard Logo
20 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
