Question about Mitsubishi WS-65907 65" Rear Projection Television
Problem with the picture
Okay, someone gave me this tv and I was excited til I turned it on. I have a picture but, it looks like someone pushed the picture backwards into the tv (like the picture is an arc.) The colors are okay, it's just the picture. The guy who gave it to me said it would cost 500-700 dollars to fix but, didn't tell me what was wrong with it. Any help?
    President:
  • 3,130 Answers
You need to replace the convergence ICs in this TV set. If you know how to solder and work on printed circuit boards and can follow a circuit diagram, this should really not be a difficult thing to do. If you do not have ALL of these talents, play it safe and call in a pro to assist you in this repair as this TV set is NOT the place to be experiementing around inside of. Good Luck
Posted on Sep 28, 2007
SOURCE:
Red hues all over the images on screen
The TV is a plasma screen. There are several circuit boards that will go bad over time that affects the picture quality. TV Parts Universal TV Stands DLP Chips ShopJimmy You can get the parts here and replace those boards yourself.
Apr 10, 2017 | Panasonic TH-42PZ700U 42 in. Plasma...
I have a 1998 Mercury Mountaineer and I have a oil leak some where and it causes a little smoke. So I went to buy this brand which that stops the oil leak when I pour it in the oil tank, nothing happen...
I have no idea what your talking about
Oil Leak Where -- Engine Oil ?
There aren't any products that stop leaks
They just take your money thru advertizing
Smoke coming out of what & where?
Tell us the history on your vehicle
Have you had it looked at by a repair shop?
May 24, 2011 | 1998 Mercury Mountaineer
Can't get a picture - Turn on TV - put DVD into player - with rem
first of all, is it on the correct av channel, plugged into av1 and av1 selected on the tv.
is the lead good, can you swap around some leads with other known to be good leads.
are the leads pushed in fully, a scart lead can sometimes look like its pushed in fully when its not.
check for bent pins on each end of the leads.
Mar 22, 2010 | Televison & Video
Tv okay when switched off last hight.This mirning
make sure the lesrd are pushed in on dvd avd tv
Dec 16, 2009 | Sharp Televison & Video
I lost my picture I still have sound but no picture.
I have a Philips Magnavox Projection TV.
I had dish satelight install on my TV. It worked well for two days, then the picture started showing in a square box. I ffixed the convergence and it seemed okay. The next day I turned on the tv and it had sound, but no picture. When I press the status button, the picture would come on then go right back out. Now I don't have any sound or picture. Here is the model information:
Brand: Philips Magnavox
Model #: 9P6040 C104
Serial #: 51190366
Chassis # PTV843
Manufactured: Nov. 7, 2000 (3910K071H)
TV Receiver Listed: 347K E10839
Amps: 3.7
HZ: 60
V: 120
Can someone please, please help me!
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
NO sound on TV Picture fine, sound when watching DVD
check your scart male connecter ends are pushed all the way in.
Jan 15, 2009 | LG 52SX4D 52" HDTV
I need instructions for a jumbo universal remote
im going to tell you automatic searching to operate your tv.... turn the tv on..
push the tv button and the on off switch at same time and watch if the led is steady ,leave the buttons., push play button and wait 5 seconds til the led finishes flashing you have to do this about 20 times to be complete secure your remote control doesnt control your tv....but if the control found the code the tv turn it off push reverse button and leave it and wait two seconds to turn the tv on and that set push stop. ........test all functions on your remote control to the tv.....saludos.
Nov 15, 2008 | Universal Remote Control Remote Control
Mitsubishi vs-50609 wont stay powered on
Hello nicolastran,
I gave this advice to someone with this same problem so here it is again:
It sounds like your shutdown circuit is being activated. This is due to excess current being drawn. This usually happens in the High Voltage section of the TV or one of the deflection stages. Due to the nature of this problem I would suggest that you take it to a local TV repair shop or have a TV repair person come out and take a look at the issue. The HV section is dangerous and should be dealt with by a qualified TV repair technician.
Thank you,
I hope this helps
Shuttle83
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
MY SIDEKICK II
Take the refill card and your phone to the dealer you purchased the refill card from. They should either help you install the minutes or buy back the card.
Ken
Jun 24, 2008 | T-Mobile Sidekick II
Mitsubishi WS-65907 65" Rear Projection Television Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
