Question about Pool & Spa
Clean electrodes on clearwater D10 - Pool & Spa
Do I have a bad spark modulator or a bad electrode?
Yes, it does sound like you have a bad spark module. But it could be a dirty spark electrode, allowing most of the voltage follow the "dirty path" to ground instead of going through the air. Make sure the electrode (the insulator) part is clean and dry. If you still have a weak spark (or one that goes out when the gas is turned on), they you probably have a bad spark module. If you want to know for sure, try swapping 2 spark wires. Remember that when 1 ignitor sparks, they all (are supposed to) spark.
Nov 07, 2014 | Kitchen Ranges
Creedence clearwater revival rock band history
Creedence Clearwater Revival-occasionally shortened to Creedence or CCR-was an American rock band popular in the late 1960s and early 1970s.
The band consisted of lead vocalist, lead guitarist, and primary songwriter John Fogerty, rhythm guitarist Tom Fogerty (John's brother), bassist Stu Cook, and drummer Doug Clifford. Their musical style encompassed the roots rock and swamp rock genres. Despite their San Francisco Bay Area origins, they portrayed a Southern rock style, singing about bayous, catfish, the Mississippi River, and other popular elements of Southern iconography.
Creedence Clearwater Revival's music is still a staple of American and worldwide radio airplay;[1] the band has sold 26 million albums in the United States alone.[2] Creedence Clearwater Revival was inducted into the Rock and Roll Hall of Fame in 1993.[3] Rolling Stone ranked the band 82nd on its list of the 100 greatest artists of all time.[4] Their musical influence can be heard in many genres including southern rock, grunge, roots rock, and blues
Jun 03, 2014 | Measuring Tools & Sensors
5 burner gas Vicking stove top keeps clicking after is on
Their are 2 possible reasons the igniters would continue to click after the burner is lit.
1) the burner is slightly dirty and the part of it very near the electrode is not burning correctly so the igniter doesn't think the burner is lit so it will not tell the spark to turn off. It could be cleaned by using steel wool and cleaning the burner holes near where the electrode is and then use a paper clip and poke through the holes on the burner to clear them so they burn correctly.
2) the electrode (the spark plug at the burner) is cracked so even though the burner is lit so the electrode can not sense that the burner is lit and wont tell the spark to turn off,so if having cleaned burner it still clicks after burner is lit the electrodes would need to be replaced.
GENE
Oct 08, 2011 | Kitchen Ranges
What do i set the spark plugs to before i install them.
Check the plugs for deposits and wear. If they are not going to be replaced, clean the plugs thoroughly. Remember that any kind of deposit will decrease the efficiency of the plug. Plugs can be cleaned on a spark plug cleaning machine, which can sometimes be found in service stations, or you can do an acceptable job of cleaning with a stiff brush. If the plugs are cleaned, the electrodes must be filed flat. Use an ignition points file, not an emery board or the like, which will leave deposits. The electrodes must be filed perfectly flat with sharp edges; rounded edges reduce the spark plug voltage by as much as 50%.
Check spark plug gap before installation. The ground electrode (the L-shaped one connected to the body of the plug) must be parallel to the center electrode and the specified size wire gauge (please refer to the Specifications chart under the hood for details) must pass between the electrodes with a slight drag.
Hope this helps.
Dec 21, 2010 | 1998 Cadillac DeVille
Zodiac clearwater LM3-15
Just found the instructions for this at this address
http://www.zodiac.com.au/media/25135/zodiac%20lm3%20owners%20manual.pdf
worked beautifully....good luck.
Sep 07, 2008 | Zodiac Nature 2 Cra30 Replacement...
PURCHASES LISTED IN THE PROGRAM GUIDE?
If you have a D10-200, use this manual.
If you have a D10-300, use this manual.
Look in the "System Preferences" section.
Feb 29, 2008 | Directv D10 DTV Receiver
Pool & Spa Logo
24 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
