Question about Philips Dh-16a3s & Lite-on Dvd/cd Rewritable Drive Sata 5.25"
LITEON DVD/cd rewritable device not reconized
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 40 Answers
Since the system originally had another version of Windows did you run the Upgrade Advisor and
check the Compatibility Center for the CD/DVD compatibilty (and other devices as needed).
Windows 7 Upgrade Advisor - please run this now.
http://www.microsoft.com/windows/windows-7/get/upgrade-advisor.aspx
Also check the Compatibility Center (for major devices)
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
Check with the System maker and the Device maker for information about drivers for Windows 7.
(BIOS, low level chipset drivers, and other major device drivers).
Check these :
The DVD drive does not function after you install Windows 7 - these are different Sony drives
however the same issue could be affecting your drive.
http://support.microsoft.com/kb/975270/
Your CD drive or DVD drive is missing or is not recognized by Windows or other programs
http://support.microsoft.com/kb/982116
If the System can run Windows 7 AND there are drivers for the devices these might help :
References to Vista also apply to Windows 7.
Stage 1 : Please do all the below even if you have done some before as it is often the total
process which solves the issue.
Try this - Control Panel - Device Manager - CD/DVD - double click the device - Driver's Tab -
click Update Drivers (this will likely do nothing) - then RIGHT CLICK the drive - UNINSTALL -
REBOOT this will refresh the default driver stack. Even if drive is not shown continue
below.
Then work your way through these - remember the drive could be bad, could have a loose
cable or slight corrosion on the contacts (usually for a laptop) and other issues.
http://support.microsoft.com/kb/314060 - a Mr Fixit
Manually try this fix if the 314060 Fixit did not work
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Your CD drive or DVD drive is missing or is not recognized by Windows or other programs -
a Mr Fixit
The CD drive or the DVD drive does not work as expected on a computer that you upgraded to
Windows Vista
http://support.microsoft.com/kb/929461
When you insert a CD or a DVD, Windows Vista may not recognize the disc
http://support.microsoft.com/kb/939052
Your CD or DVD drive cannot read or write media - A Mr Fixit
http://support.microsoft.com/gp/cd_dvd_drive_problems
CD/DVD drive does not appear in Windows Vista, or you receive this error during Windows Vista
setup after booting from the DVD (AHCI)
http://support.microsoft.com/kb/952951
CD-R drive or CD-RW drive is not recognized as a recordable device
http://support.microsoft.com/kb/316529/
Hardware devices not detected or not working - A Mr Fixit
http://support.microsoft.com/gp/hardware_device_problems
Another possibility is that the cables are loose. Remove ALL power, then check cables in both
ends. Remove and replace, do not just snug. For laptops you can often clean the power and
data contacts with a pencil eraser.
Some DVD drives do not use the Windows default drivers so check with the System maker and
device maker to see if there is firmware or drivers for you drive if needed.
Stage 2 : You could have drive issues as the CD/DVD is actually 4 drives in 1 case ( CD & DVD
burn and CD and DVD read). So it is not unusual for 1 or 2 parts to not function while the others
do so properly.
Did you complete the troubleshooter for the drive that still does not work? There are some
registry entries that the troubleshooter does not fix and those "might" be the cause.
Check with your System Maker and Device maker for both possible firmware updates and the
correct Registry entries for your drive.
These are the keys I think are the ones in question - for the CD/DVD drive sub-keys of course
as there will other sub-keys in these keys. Be sure to ask for specific keys involved as well as
the settings.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\IDE
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Hardware Profiles\0001\System\CurrentControlSet\Enum\IDE
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
You probably can find more info here and maybe even the exact registry settings for your CD/DVD
drive from someone with the same model.
Forums - a lot of real expert help
http://club.myce.com/
CD/DVD units
http://www.myce.com/storage/
Use DevManView to locate CD/DVD in registry (be careful and make a Restore Point before
changing anything) - find the device in DevManView and then Right Click on it Open in RegEdit.
DevManView - Free - an alternative to the standard Device Manager of Windows, which displays all
devices and their properties in flat table, instead of tree viewer
http://www.nirsoft.net/utils/device_manager_view.html
Hope this helps.
Posted on Oct 20, 2013
I need a driver for LiteOn DVD recorder eSAU208-01
You'll find firmware updates here:
http://us.liteonit.com/us/index.php?option=com_wrapper&Itemid=153
You may also want to have a look at the Utilities page while you're there.
Nov 11, 2009 | Lite On LiteOn 16X Dual Layer DVD...
I have HP A6403W with an ATAPI DVD A DHI16A3L ATA Device that doe
if you download the firmware for you cd rewriter and flash it, but make sure no other programes are running that normally works
Mar 30, 2009 | HP Computers & Internet
My dell d610 laptop has dvd/cd rw i want to know if this means i have dvd rw too if not what should i buy so that i will have dvd rw hopefully it will be something i just plug in this is my first computer...
Your built in CD Drive is a DVD player and regular CDR - CDRW burner, this means you cannot burn DVD's. To burn DVD's I would recommend you purchase an external DVD burner, here are some links to ones that are compatable to your computer.
Asus - Good Reviews
LITEON - Also has good Reviews
Mar 20, 2009 | Dell Latitude D610 Notebook
I have a Lite on 20X DVD/CD Writer & rewriter for 6 months, now for some reason my computor does'nt seem to recongnize it and it needs me to play my set up CD whitch I cant find,if its possible...
Go to the bios of your system, then check whether the device is detecting or not, if not replace bus cable , check power connectors,
how do you like the solution please rate it i will appreciate your comments
Oct 28, 2008 | Lite On Computers & Internet
I require a compatable programme for a LITEON DVD/CD Writer & Rewriter
Any popular program such as Roxio or Nero will work. If you have still have a problem, you may need to update your firmware. See http://club.cdfreaks.com/f44/liteon-dh20a4p-h-fast-burn-enhanced-overspeed-enhanced-oht-firmware-new-231875/
for complete instructions
Apr 27, 2008 | Computers & Internet
System cannot see lightscribe drive
try to update the firmware of that drive. then try to go to device manager to see if there are any changes.
Mar 23, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
DVD/CD 20XWRITER/REWRITER
Of course, since the drivers needed should be compatible with Vista... that's the problem on Vista, it still has a lot of problems with the drivers of old peripherals.
Visit Vista website and find a compatible driver or ask on their online help desk on what to do with your printer;s driver....
Good luck.
Feb 04, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
Dvd burner
First off do you have any burning software installed? Roxio or nero or the like? sonic record now? etc etc...
Sep 14, 2007 | Lite On LiteOn 16X Dual Layer DVD...
Philips Dh-16a3s & Lite-on Dvd/cd Rewritable Drive Sata 5.25" Logo
93 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
