SOURCE: American Standard Champion toilet keeps running
Readjust the float. the longer it is the more leverage the fill water will have on it. good luck. The fill valve does come apart and cleaned if there is debri in it. Turn the water off first:)
SOURCE: Toilet continues to run. THe plastic float cup
The adjustment is inside. It just needs to be adjusted.
SOURCE: How do you adjust the float valve in a kohler one
You will see a metal clip on the rod that connects to the square float lightly compress the clip for more water in tank lower clip for less raise the clip if this does not work you need to service the valve
SOURCE: WATER KEEPS RUNNING ON TOILET
The screw can be used but only for minor adjustments. The missing tube should be replaced. If this doesn't solve the problem purchase a repair kit. The repair kit comes with everything you need for about $20 and can be installed yourself (saving $$$ if you called a plumber)
SOURCE: I have a Jacuzzi Perfecta toilet (bought Aug. 21,
Have you tried shutting water off and take top of valve appart and flush it out. It may have something in valve causing water to be restricted. It will have an arrow on it to direction to get it to come off.
Take appart and clean rubber disc and you can put something over top of valve , a small cup or something to enable you to flush the tank. Have someone help you and hold the cup above the valve so that when you turn water on for a few bursts to flush out the valve it goes into tank.
The actual stream that flows through valve is restricted down to almost 1/8 " opening so it wouldn't take mush to block the flow of water.
The disc you take out you can replace it, if it seems to be damaged and not working correctly. That will affect the flow also.
Testimonial: "I took the valve apart. It is working like it is supposed to. That sure is a tiny hole for the fill water to shoot through. that is why it is so slow. It still whistles when filling. Tnx Walter Neaves"
