Question about Horizon Venture Super Metal Halide Lamp
How to test CD-Z400M? - Horizon Venture Super Metal Halide Lamp
Why doesn't CD play?
The CD player has failed and will have to be replaced
Feb 02, 2016 | 2002 Isuzu Rodeo
Dell error code 2000-0151 incorrect status 28
That error indicates an "incorrect status" of your optical drive. I suggest you run the Dell diagnostics on your drive. To test your CD/DVD drive from the utility partition:
1. Reboot your system. When you see the Dell logo, hit F12 to enter the boot menu.
2. Select Boot to utility partition.
3. Select Test System.
4. Select Custom Test.
5. Use the arrow keys or mouse to select your CD/DVD drive.
6. Insert a CD or DVD.
7. Click Run Tests.
8. Write down any error messages.
Feb 28, 2014 | Dell OptiPlex 390 DT Desktop Computer...
SAMSUNG HM500JI
Bro, when you see "SMART overall-health self-assessment test result: FAILED!" then this hard drive is either dead or dying. There isn't much you can do other than replace it now.
Oct 16, 2012 | Samsung HM500JI 500 GB SATA Hard Drive
Hp g60-120us computer will not boot, passes
hi
You need to set the boot seq to boot first from the dvd or cd drive, and try the dvd or cd in an other computer first!
May 30, 2010 | HP G60-120US Laptop
It will not turn the cd, the motor does work
this brand from all my exp 43 yrs. is known for lasers going bad. so yours has gone south... buy a cheap dvd player to play your cds it will last a lot longer...
Nov 07, 2009 | Sony SCD-CE595 5-Disc CD Changer
Lost CD software for philips gogear SA3245/37
i have the cd and i can make you a copy because you need it because the mp3/mp4 have a special format to use to put into the mp3/mp4 but any ways i will give you a copy for 6 dollars plus shipping and handling if you need it email me at amitahuja23@hotmail.com
Jun 27, 2009 | Audio Players & Recorders
Aspire 5002 WLMi getting turnoff
There is a CD tool called "Ultimate Boot CD" which can be downloaded athttp://www.ultimatebootcd.com. On this CD there are quite a few toolsthat you can use to test your RAM, CPU, Hard Drive, etc.. for problems.Just boot up with this CD and select the corresponding testing programto use. Test each component until you find the component causing the issue.
Cause it seems something is overheating.. Probably the CPU.
Aug 18, 2008 | Acer Aspire 5002WLMi Notebook
Emachines T3882 desktop w/one cd-dvd combo drive[no floppy]
Download the drive test for the hard drive. Put the drive in your other computer and run the test. If it test good on simple test do the long test. IF IT COMES OUT FINE, Run the Zero program and then try to install the O.S. Check your BIOS settings and make sure everything is set right. You are on the right track. You just did not know how to test the drive. If it is a Toshiba you will not find a hard drive test. You might be able to use the Maxtor or Seagate drive test. Use the windows version if you can. If you can't do any of the test, right click on the drive and check for errors.
Rate me if this helped.
May 29, 2008 | E-Machines eMachines Desktop PC
Horizon Venture Super Metal Halide  Lamp Logo
71 people viewed this question
Top Horizon Garden Experts
Dennis Key
Dennis Key
john h
Are you a Horizon Garden Expert? Answer questions, earn points and help others
